#112
Re: PT 2024.3 | Released
Installed HD drivers and PT 2024.3. Everything working great. No issues.
Favorite feature so far is detachable Melodyne and Clip Effects tabs, so I can move to a different monitor. Dell XPS 15, Win11, MTRX Studio+HDX |
#113
Thank you, I look forward to hearing more. |
#114
Thanks so much, Marianna! Sent from my iPhone using Tapatalk
Ben Rubin Producer//Mixer//Bassist//Composer benrubin.com ------------ PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive, Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1 |
#115
How about legacy controllers like Icon/C24? Are they still working with this update?
2018 MacMini i7, 10.15 PT 23.9 HDN, 2x192 i/o D-Command |
#116
In Rosetta on Mx or on Intel, yes.
offthewallproductions Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4 Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface. Genelec 1031AP/7070A 5.1 monitoring. |
#117
Does "significant performance improvements utilizing Efficiency Cores in M1, M2, and M3" apply to running PT in rosetta? (Boz holding up the works.)
Also, could you guys finally fix the "quick reply" at the bottom of every thread? It still psychs me out. |
#118
I didn't do any exact tests because unfortunately I read the news about the performance improvement only after installing PT 2024.3, but now I see 16 cores instead of 12 (both Rosetta and Native), and I can play sessions that previously had exceeded the maximum CPU limit so they stopped continuously, now they don't stop anymore I can't say the exact percentage of improvement, I imagine it also depends on which processor it is, the relationship between efficiency core and processing core yesterday I did some tests between Rosetta and Native, and, with great surprise, I found that some plugins (to be precise UADx distressor, stereo) are much better performing in Rosetta mode than Native mode... to give an order of ideas, in Rosetta around 300 tracks, in Native around 220 tracks, so the difference is substantial the interesting thing to do would be to go back to PT 2023.12 and do more "scientific" experiments, but since everything is working well I prefer not to touch anything |
#119
Is anyone else having issue with MIDI playback?
I have a simple session, WA Triaz(native) for drums, UA Electra and Diva. All on stereo Instrument tracks. I've got a four-bar MIDI chord progression I recorded looped playing the Electra. Triaz is playing its own internal sequence. I am messing around with Diva on top of the other two and have not recorded anything yet. Almost every other time I switch presets on the other two instruments, Electra stops responding to the notes in the MIDI clip. There is also an instance of Scaler on a separate instrument track that I use to pull chords from, but is not playing anything. It usually gets stuck on the first note then plays nothing. Sometimes it will start playing again mid sequence, some times it needs to be restarted... Some times it takes a few tries to get it play back the chord clip. I tried switching out Electra, still happens with other instruments from different manufactures. I've tried switching from the MIDI out of the instrument channel from Chain to directly into the instrument. Same problem. Mac OS 13.6.4, Mac Studio M1 Max, 64GB Ram - All instruments are up to date..... Why can't I edit my old signature?? lol |
#120
How about command 8? Is that still working on Mac?
What I would like to see in ProTools in 2024 ! | stevegalante | Pro Tools | 125 | 03-25-2024 12:37 AM |
Runnind PT 10 and 003 Factory with NEW 2024 Mac | PRSWILL | macOS | 20 | 01-18-2024 07:08 AM |
