Snapshot Help :confused:
on a Venue SC48
i trying to set up a show with snapshots, i want the snapshots to remmember what plugin inserts ive selected (i know i cant change the plug-ins themselves) but can the channel insert pick offs be included in snapshots??? what am i missing |
Re: Snapshot Help :confused:
do you mean bypass on plugins?
Re: Snapshot Help
yeah i guess its called a bypass switch...
the section im refering to is the top right hand bit on the D-Show screen at the moment ive come up with a work around = ive set up duplicate channels for those i need to change plugins on between snapshots...(not ideal but its getting the job done) |
Re: Snapshot Help
Using snapshots it's possible to change which plug-ins are inserted on channels. The routing to/from plug-ins is stored as part of the PLUG-INS scope on the Snapshots page. Make sure the plug-ins are first added to the snapshot, using the small MIDI/Plug-Ins section at the top right of the Snapshots page. Sheldon |
This is a perfect segue to plug the Avid VENUE Webinars. There are 2 that cover snapshot use.
http://www.avid.com/elqNow/elqRedir....com/p80031603/ http://www.avid.com/elqNow/elqRedir....com/p33947031/ I bookmarked them. Snapshots are powerful tools and multiple views of the webinars are most helpful. |
Add-on question...
When you store snapshots, it stores everything, then you can scope what you want to recall... When adding a plugin to a snapshot, does the snapshot remember what the plugin looked like at the time of creating the snapshot, or does the snapshot only retain plugin information when you add the plugin to the snapshot? |
Snapshot only remembers plugin settings if it's added to the snapshot
You have to explicitly add plugin(s) to a snapshot, from the plugin overview window. Button on lower-right corner of each plugin (below the insert button). If you do that, the snapshot will remember the plugin knob settings.
Scott Helmke TC Furlong, Inc. |
Snapshot quiz | james tebb | VENUE Live Sound Systems | 2 | 04-29-2009 11:22 AM |
Snapshot strategies etc..... | Drew Mazurek | ICON & C|24 | 7 | 04-24-2009 06:18 AM |
:confused: Confused Re: Expansion Chasis | BA Studios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-26-2008 08:24 AM |
Snapshot automation | neilbenezra | Post - Surround - Video | 1 | 06-14-2006 01:31 AM |
Snapshot of Mixdown | Busterman | Pro Tools TDM Systems (Mac) | 6 | 03-03-2003 07:58 PM |
