Can the 002 work with a P3 850Mhz IBM T21 laptop?
XPPro
512MB RAM 30GB internal HD Pentium 3 850Mhz Can the 002 work at all with this system or I'm wasting my time? I would need at most 2 renverbs + 2 SampleTank channels at the same time. I need very low latency for live performance of my band. I guess stability would be a crucial factor too...
Digi002 Rack Mac Pro 8-core 3Ghz 8gb RAM 3X 500GB 7,200 SATA DRIVES OSX 10.5.7 PTLE 8.0cs3 |
Re: Can the 002 work with a P3 850Mhz IBM T21 laptop?
The 002 requires a firewire port, this Laptop does not have firewire port build in. unless you have a PCMCia firewire card, you can't use it to run the 002. Check the specs on the laptop before you make your purchase. Good luck
Happy recording ya'll |
You're right. I would have to buy a PCMCIA FireWire card. My guy at SweetWater told me that they had a lot of problems with such cards. The card itself is affordable, but I'm not sure if it'll handle the throughput.
But I am now looking at the economics of the 002 a little differently: option1 - digi 002: ------------------- $2000, but I can sell my 001 and get back say $500, so really $1,500. works on both my desktop studio machine and my laptop on the road option2: -------- Keep the 001, buy AmpliTube (which I really want) $300, buy the MBox $500, buy Renaissance Waves $300, Buy SampleTank LE $100: total: $1,200. So for an extra $300, I can have a 8 input digital mixer on the road, and everything else as before, plus 3 great plugins. I'm starting to think that if I found a buyer for my 001, I'd probably switch to the 002...
That's a good way of looking at it, If, You can wait for the XP drivers for the Mbox and If on the road, all you will need is a stereo input. WHat I did when I need to record on the road is: I bought a docking station for my laptop which is an old Dell, and the docking station has two PCI slots in it, so I bought a AMI III card for $100 and put it in there, So now I have a 2 channel input recording solution, and If I need more I bring my Yamaha 01V digital mixer with me and add another stereo input. So there are options out there, just do what is best for your need. By the way I do have the IBM T21 as well, but I'm not sure IBM makes a docking station that allows you to add PCI cards to it. Do your research and purchase what is best for you. Good luck and happy recording.
I actually have a docking station for the T21, came for free with the laptop when I bought it. It has no PCI ports though, only 2 extra PCMCIA and USB.
For what it's worth, I have a T20 that I use for work. There is no way I would use it for DAW type stuff. I say this because it can be stressed using Apps like MS Project or multitasking. I think heat removal is a problem with laptops and the soloution is to slow them down.
Greg
Protools PC, i9 10990, Gigabyte X299 mobo, 64 GB ram, EVGA Nvidea GT 720 TI video card, Win 10 Pro, PT Ultimate (Native) 2024.3.1, HD Omni, HD I/O 16x16 . |
Will the 002 and LE work on my laptop? | nughuffer615 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-08-2009 10:47 AM |
Will the M-box work with my laptop? | Siren | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 07-06-2006 02:39 PM |
will PT LE work on a laptop? | VanEdge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-25-2000 01:30 PM |
1GHz RDRAM vs. 850MHz SDRAM system??? | deemo119 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-25-2000 03:16 PM |
1GHz RDRAM vs. 850MHz SDRAM system??? | deemo119 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-18-2000 04:18 PM |
