Old 09-28-2011, 01:18 PM
cuibono cuibono is offline
Default PT will only recognize Mytek with HD3 cards in reverse order
I'm trying to interface a Mytek 8x192 with a HD3 system, on a 2010 Mac Pro. This is a clean install - the mac is brand new. I installed all the cards in the proper order (core in slot #2, and the accel cards in #3 and #4). The cards pass the DigiTest, but digitest reports the cards are in the reverse order (core in slot 2, accel cards in slots 1 and 0).
I've read that this is normal behavior. But, when I start PT, I get an error saying "Unable to find an Audio Interface attached to the first HD card. Please check power and digilink cables. Click OK to rescan".
I've looked all over the internet for solutions, and tried many of them. The only way I can get PT to recognize the Mytek is if I reverse the order of the HD3 cards (core in slot #4, accel cards in #3 and #2). When I do this, DigiTest reports that the cards are ordered correctly (core in slot 0, and accel in 1 and 2), but the cards fail the digitest. Strangely though, ProTools starts up and works fine - and it recognized the Mytek. I'm not comfortable with leaving things set up like this, and would like to see if there is another solution.
Anyone have similar problems?
Old 09-30-2011, 05:57 PM
kooz kooz is offline
Default Re: PT will only recognize Mytek with HD3 cards in reverse order
HD3 Accel on a G5 with 3xMyteks...
your issue sounds strange...are you sure you have the TDM flex cables between core -> Accel1 and accel1 -> accel2 installed correctly?
Old 10-03-2011, 05:49 PM
I've tried reversing them, and I get tons of errors. Safe to say they are in the proper order...
Old 10-17-2011, 12:19 PM
no others with this problem?
Old 10-18-2011, 10:52 AM
docric docric is offline
Previously also on a G5 w/ 3x Myteks (now in Win7)... worked fine...
It's a long-shot, but, when you switched the flex cables, did you also try switching going from the B port to the A port on the cards?
IOW, normally Core->accel1->accel2
port A->portB,
port A-> port B
Seems I remember a mobo build (win 7) that only worked when I started from the B port of the cors to the A port of accel #1.... Then again, maybe I just need to lay off the Rock !
-C' ya'
Rick
MacPro 7,1; 16 core OSX 13.5.2
PT 2023.9; Eucon 2023.6
Dock/S1/2x iPad
Old 10-18-2011, 11:04 AM
DigiTechSupt's Avatar
port A->portB,
port A-> port B
'Normal' is actually Port B on the core to Port A on the next card. Reversing them can definitely cause problems.
Is it possible the OP has the flex cables reversed?
Avid Audio Tech Support
Support FAQ
Old 10-18-2011, 12:42 PM
mix109 mix109 is offline
Asuming that the Primary Port of the Protools HD DIO card is connected instead of the Expansion one_
Any chance that the EPROM of the Protools HD DIO card,or the Mytek equivalent need an upgrade?
Old 10-27-2011, 11:57 AM
I have tried switching the flex cables orientation. The system will not work with them in the wrong configuration.
I have the latest firmware in the Mytek. Are there firmware updates for the HD system hardware? I don't see them anywhere...
Pt HD9 doesn't recognize Pci Accel Cards lecreak Pro Tools 9 5 12-01-2010 08:23 AM
Order of Cards wallygrant Pro Tools TDM Systems (Mac) 11 01-12-2008 02:53 PM
MBox move from 10.3 TO 10.2 (reverse order) Chris Nelson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-20-2004 05:39 AM
Correct order for PT Mix cards Captive 8 Pro Tools TDM Systems (Mac) 1 10-16-2002 12:55 AM
what order for pci cards? chuck Pro Tools TDM Systems (Mac) 9 05-08-2001 05:44 AM
