Upgrade from 7.4 to 8.0.1 ?
I have an older Dual PowerMac G5 running PTHD 7.4 on OSX 10.5 (leopard) It's running fine but I have a Blackmagic Decklink and would like to have native video out PCI. version 8 is supposed to do this I tried to find an upgrade from 7 to 8 but had no luck. Is this possible this day and age? Thanks |
Re: Upgrade from 7.4 to 8.0.1 ?
I actually upgraded from 7.4 to 8.0.1, with no troubles. . . . but, I don't do any video work within PT, so I can't attest to that. You'll have to purchase PT 8, and then upgrade to 8.0.1. Do not upgrade to 8.0.3, because that is supported only with Intel based machines. There may be a CS update to the 8.0.1, but I can't really remember - it's been over a year since I upgraded. I sure hope this helps you.
Due to budget cuts the light at the end of the tunnel will be turned off until further notice. http://www.gidakdigital.com |
yeah, I had to go from 7.4 (or was it 7.4.2csSomething???) to 8.0 and then 8.0.1cs2, the last version w/ support for PPC machines.
Let the software updater run and check your plugs for the current versions on first run. It will save you plenty of headaches down the road. |
Thanks both for your help.
I was hoping to use the "Video out PCI-e" feature introduced in v8 along with my Blackmagic card, but it turns out my card is standard PCI and not PCI-e. So I'm stuck at 7.4. here... Cheers |
I bought mpowered 7.4 with free upgrade to ver 8. HOW DO I UPGRADE | cmangeot | Pro Tools M-Powered (Win) | 4 | 02-21-2020 04:18 PM |
Pro Tools 10 Student Version- To upgrade, or not to upgrade? | KFPCalvin | Windows | 4 | 04-12-2012 08:37 AM |
Upgrade to Pro Tools 8 (with upgrade dvd) asking for Auth code? (HELP) | Mista808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-12-2010 01:40 PM |
Upgrade question - can I use mbox2 micro upgrade on 002 system? | spreston | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-22-2009 11:22 AM |
Upgrade link 'Sorry, no product found.' How can I upgrade?? | dim | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-15-2008 12:44 AM |
