Mix/edit window
Hi
I just got a MC control v2 and updated my Pro Tools 8 to Pro Tools 9. Isn´t it possible to toggle between the mix and the edit window on the MC control with just 1 bottom. There is a soft key with the mix/edit function but when I press it nothing happens. Hope some one can help with this. |
Re: Mix/edit window
Did you activate Eucon in PT?
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
Re: Mix/edit window
Yes it is activated and all other functions seems to work fine. Just not the toggle between Mix and edit window.
Re: Mix/edit window
Hi there,
indeed the shorcut assigned to the softkeys ( touchscreen ) is broken. Change it to Command+Shift+0 and you'll be fine. Regards |
Re: Mix/edit window
Thanks a lot AlexJMR now it is working
Mix Window Freezes but Edit Window works fine. | wwicklund | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-10-2022 10:57 AM |
Tracks Showing in Mix window but not Edit window | midi sordino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-23-2010 09:43 PM |
dual monitors... edit window + mix window | T-Jac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 37 | 04-23-2010 02:21 PM |
Cannot change EDIT MODE in edit window | Xavior | Pro Tools M-Powered (Mac) | 2 | 05-24-2007 12:51 AM |
How do you scroll the window with the audio on edit window? | fsilano | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-01-2001 09:53 AM |
