Managing input signal strength during tracking liv
I recorded an 18 member group of singers in a fairly reverby sanctuary last weekend. Though I got good tracks, I had trouble managing input levels, specifically clipping.
My signal chain is simple, 4 condensor mics -->002r --> powerbook --> PTLE 6.2. The songs had a low average volume, and then would crescendo at several points and clip, leaving me with an average signal strength of, I don't know in -db, but the PTLE signal indicators were hovering around 45-55%. It became a nerve wracking game of scrambling to turn down 4 knobs during loud parts of songs I didn't know (manual compression/limiting...ghetto). It was pretty much a live stuation. One or two takes, no doing quiet parts and then resetting levels and doing loud parts. Can I improve my session experience by adding inboard compression harware between the mics and the AD converters in the 002r, or is that the wrong way to go about it too? Thanks fellas, dnash |
Re: Managing input signal strength during tracking
If your already clipped recording aren´t too bad try AS ClipRemover from the new FREE BF plug-ins from DIGI. regs
last: PT11.3.1 |
Rather than opting for a compressor, why not get a preamp,although it is always good to compress a vocal before tape, in some casses you might not know if the type of compression is gona suit your mix/end result!! So try optimising your inputs to capture the loudest part without clipping, rather than hope'n for the best(im not tryn to be smart/rude)!
did the signals distort or did the meters indicate clipping?? (because they are pretty booggie meters) go to: psp-audioware.com - Vintage meter elementalaudio.com - Inspector or the Bomb Factory plugs has a meter bridge(all are free & seriously help) who needs more tracks(surround is the way) Aido |
Unfortunately theres no reparing the clipped signals. In the future, set your levels for peak performance levels leaving you some headroom. for the 002/002R nominal levels sohould be targeted at -14dbfs.
Thanks guys. That's what I thought about the inboard compression. Fortunately I only averaged about 3-4 brief clicks per tune by staying on the gain knobs like stink on a dog. I did do my best to set the levels by having them reherse the loudest parts of a song while I set them, but they generally sang louder when actually tracking.
Only a few of them caused noticeable distortion. So I guess I'm sneaking by on this one. I'll also check out that clip remover plugin. Sounds like a tool to do the job I did manually (finding the peaks and quieting them down 2-3 db with the gain plug). Take it as a lesson learned. Thanks again. |
If the peaks are short enough you could redraw the waveform with the pencil tool.
Managing Signal Level through SC48/System Controller/Amps | Tigerspill | VENUE Live Sound Systems | 10 | 04-21-2013 02:01 PM |
Signal strength over distance | kevinc333 | General Discussion | 5 | 01-15-2009 10:17 AM |
Advice on Signal Flow for tracking with 002 | Leadfinger | Tips & Tricks | 9 | 01-24-2007 02:48 PM |
help!: Tracking mic gains off but signal peaking?? | mach-1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-01-2005 09:39 PM |
Help, in the 001 I have no input signal | Santos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-27-2002 11:46 AM |
