Flex channel sc48
I am having an issue with the flex channel in conjunction with a pair of latched channels. I attach the flex channel to my lead vocal(channel 35) and when I latch 2 other channels(19 & 20) the flex channel becomes unattached again. I am aware of the difference between selected channel mode and flex channel mode and am in flex channel mode. Please help. Thanks, Jeremy
Re: Flex channel sc48
Don't you double-hit a button to lock the choice?
You can assign only 1 handle to the Flex Channel, IIRC. It can be a 1 handle stereo pair or a single mono channel.
Tim is correct. Alternately, you could assign all of the channels that need to be controlled to a VCA, and then latch the VCA to the Flex channel....
Sheldon |
So if I choose to channels in the input section, right click and click Latch, that is always going to connect those two I have selected to one-another and to the flex channel? Seems counterproductive. I often want two channels attached but not as a stereo pair, I guess there's no way to do that? Thanks for all your responses.
Any single channel can be assign assigned to the Flex channel. This channel can be a mono or stereo channel (or VCA). It is not possible to latch multiple channels, nor is it possible to link channels (other than by creating a single stereo channel). Sheldon |
Ok thanks
SC48 Flex Channel & Fan Issue Issue | toddbuckner | VENUE Live Sound Systems | 2 | 03-01-2014 12:51 PM |
SC48 in 64 channel mode (not enough layers) question | Jamie_aep | VENUE Live Sound Systems | 4 | 10-15-2012 08:04 PM |
Flex channel reall by snapshot? | chrismoran | VENUE Live Sound Systems | 1 | 01-07-2011 01:05 PM |
Venue Profile flex channel | DasTweaker | VENUE Live Sound Systems | 1 | 02-27-2010 04:44 PM |
flipped flex fader on sc48? | jbialek | VENUE Live Sound Systems | 2 | 01-06-2010 08:08 AM |
