\"PT unable to auto backup your session\" Assertion in...
I have a Powerbook G4, OSX.4, 1.67 GHz, 2 M Ram, PT 7.1, 002R, Octopre LE , OWC Mercury Elite PRo 360 GB firewire drive for session/data files. I have Garritan Personal Orchestra (RTAS). I produced a few tracks for a rock band, added some strings, etc. and started getting this error message: PT unable to backup your session: "Assertion in: CNeal0Block.cpp, line 792... The line numbers increase with manual saves and restarts.
I did the vast majority of fixes from the troubleshootin guide, incl. setup, energy saver, pace drivers, trashing prefs, databases and volumes, with restarts, and I dont have any virus protection. I'm a little nervous about re-installing PT cause I had the original version, plus a downloaded upgrade which I had to do twice and still have a couple of files with 6.9 interface hanging around. In addition to this, I was trying to add a string with GPO on another session, and in record mode, PT would not stop with the space bar, or the mouse. I had to force quit the entire Powerbook. Any suggestions? javascript:void(0) Thanks! |
Re: \"PT unable to auto backup your session\" Assertion in...
Hi Gordon,
Give this a shot. Create a new Pro Tools session (empty) and then choose File > Import Session data and just bring everything in new. Then try to save or do a Save Copy In if needed. It has helped me before with something very similar, so I thought I would suggest it. Cheers, Scott
Scott Church |
Thanks Scott, I tried a new session and it won't let me save it!. I get the message: "Assertion in CNeal0Block.cpp at line 1242."
Ouch. gord |
I tried the new session again and it saved, even though I got the message. I then tried recording the midi. This time it would stop, but Igot the message: "could not perform requested operation because of assertion in CNealblock.cpp line 1242."
Also, it did not save what I recorded, the track was blank. Any more sugg.? thanks, I really appreciate anyone's help. javascript:void(0) |
I know this is off topic but...
Hey Scott, are you the same Scott Church from Cherokee Recording Studios circa 1984-85? Drop me a line. David Eaton [email protected]
Mac Pro (Quad core Intel, 2.66 Ghz, 3 Gig Ram) Mac OS 10.4.8 002/ M-box PTLE 7.3.1 cs4 Music Production Toolkit 7.3.1 Apogee Rosetta 200 |
Generally a neoaccess error means your DigiBase folders are corrupted - delete the folders and files as directed in the sticky Troubleshooting thread. I have seen this also occur when running RTAS Instruments which use up large amounts of RAM... usually restarting Pro Tools helps.
Rail
I am currently recieving a similar NEO assertion Error, ending in CNEOBLOCK as well. I have RTAS plug ins running in the track. How should I configure my session, so i can use the RAM I need without messing up the track?
Well, firstly have you deleted the DigiBase folders? Did that clear the error?
Rail
where is the thread w instructions on how to delete corupted digibase folders? If this is happening in more then one session would that mean that they are all corrupted, or are they having a problem navigating through external hardrives?
Session File Auto Backup crash | masaki | Pro Tools TDM Systems (Mac) | 13 | 04-12-2011 12:13 PM |
Pro Tools was unable to Auto Backup your session | NIclas Andersson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-04-2011 12:37 AM |
Someone΄s session turned off my auto backup | Audiofarm | Pro Tools TDM Systems (Mac) | 4 | 10-22-2010 07:56 AM |
Pro Tools Was Unable To Auto BackUp "NEED HELP" | SV.P ROMO | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-06-2008 09:50 AM |
What is session auto-backup good for ?? | ISedlacek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-24-2003 04:17 AM |
