how to add secondary drive to macbook ?
as recommended by pro tools user guide, it is good to add a second hard drive to the computer to add as a audio slave drive, so not to stress the primary drive. what hard drive can I use to add on to a macbook ?
bang bang bang ! see you later Let the hardware interface with the software |
Re: how to add secondary drive to macbook ?
Any external drive you can connect to it. As a general rule, avoid USB2 drives if you can, choose ThunderBolt if you can, settle for FireWire if your macbook model doesn't have TB.
...and read the specs carefully so you won't be buying 5400rpm or a green drive. SSD's are safer choice if you have no idea about oldskool spinning hard drive specs.
You could replace the cd/dvd drive with a hard drive using an adapter kit. OWC has one, that's easy to do yourself or have a tech do it.
Brian Campbell "Air mixes better than any console" Bill Porter "Humility is mighty important in this business of listening" Bob Olhsson |
Secondary Hard-Drive (PTLE8) | MythMuzik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 04-06-2009 04:19 PM |
Secondary internal drive vs external drive for PT8 ? | chrisdee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 03-24-2009 01:58 AM |
G5 secondary hard drive suggestions? | rennyren | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-11-2007 01:43 AM |
best secondary drive for a new dual g5 | coyotehill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 11-22-2003 08:02 AM |
should I use a secondary hard drive? what kind? | M.Brane | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-26-2001 12:34 AM |
