Do i realy need a seperate audio firewire drive
Ive been running my digi 003 and imac for 4 months and have just been using the system drive on the imac cus i cant afford to buy a seperate drive at the mo, but im wondering why im always reading that you need a seperate audio drive? my sessions avarage at about 30 tracks or more and im using at least 2 pluggins on each track and aux sends and mastering pluggins on the master track and as long as i keep the buffer high i have had no problems at all. so my question is do i realy need a seperate audio drive and what are the benefits for me?
i hope they dont have noisy fans but i wish my music did. |
Re: Do i realy need a seperate audio firewire drive
On a vast majority of systems, using the internal hard drive is a non-starter, which is why we don't support or recommend it. If you're able to do it, then that's all well and good and it's your choice whether or not to get another drive.
ive actually always used my internal drive rather than my firewire external, and ive had no problems with PTLE. maybe im just one of a small percentage, but still i mostly use my system drive, and when a session is finalized i just move it to my firewire drive for safe keeping.
2.0GHz Intel Core 2 Duo + 2GB RAM el-cheapo compusa generic firewire 80GB OSx 10.4.10, PTLE 7 (latest update) |
If your 30 tracks are MIDI, the hard drive speed and access isn't as important (I imagine). If they are all audio then you take the chance of it not cutting it.
On my old laptop (Dell 600M) I could record at high latency to my internal drive (for recording shows live) but when doing overdubs I always had to use an external drive. Now I have a MacBook Pro and I haven't tried to do much off of the hard drive (I'm used to using the external now). Only other suggestion from me is to ghost your working system right now and guard that with your life. The stupidest change can kill your working system and you don't want to have to spend hours tracking it down!
James Abbott 002, ProTools 7.3.1cs5, MacBook Pro Strike, Structure LE, Xpand, McDSP, Reason More money than talent! |
you will save yourself a lot of headache by getting one.
Once you start getting a high track count, you will probably experience problems recording to your startup drive. you could also consider a secondary internal drive which has always worked for me as well as firewire. get the fastest drive even if it means getting a smaller one. glyphs are overpriced but in my experience they have out performed everything else. |
If you have no problems then you obviously don't need one. I'm a bit surprised you aren't experiencing any error messages in the scenario you describe though. Well, what can I say? Good for you!
No Audio, But Just Samples. System Drive Or Seperate Drive. | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-10-2010 03:47 PM |
Any benefit of 2nd internal drive for audio instead of firewire drive? | JChance | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-15-2009 06:25 AM |
can i use external firewire drive as audio drive? | Joseph Anderson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 09-20-2003 07:09 AM |
Updated to 5.1...now firewire drive "not valid audio drive"" | blink | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 06-11-2001 05:23 AM |
001, Magma, Firewire - does it realy work? | melodious thunk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-05-2001 07:32 AM |
