Eleven Rack + Fast Track Pro
I'm having issues. I need the two mic pres from the FTP so I connected it to the 11r via spdif. Out to in, in to out. I set the clock on the 11r to external and enabled outputs 3 and 4 on the FTP. I cannot get a signal from the FTP to Pro Tools. Any thoughts on what I'm doing wrong?
2.66GHz Quad-Core Intel Xeon 6 GB SDRAM 3 1 TB WD Caviar Black Hard Drives Eleven Rack, Axiom 61 |
Re: Eleven Rack + Fast Track Pro
I don't think it will work that way. From what I can see, the Fast Track Pro does not function as a standalone converter. It's an interface to the computer only, and will only pass audio to and from the computer. The spidf i/o would be when you're using other converters, while still using the fast track as an interface, or for using an effects unit with digital i/o.
So you would need to use the fast track as your interface connected to the computer. Then you can hook up the 11R to it. Note: This assumes you have Protools 9 or M-Powered. |
Yeah, I had that thought. But I swear I read that the FTP can be used as a stand alone convereter....hmmm.
Not a big deal. I haven't used it for about a year and I was messing around. Any other thoughts?
Well, you have a couple of options. I don't know if the fast track works this way, but with the 11R and another Avid/Digi interface, you can have them both plugged in to the computer and switch between them in a session. With PT9, I don't know if this now works the same way with non Digi hardware.
Otherwise, if you're on PT9 or M-Powered, the Fast track can be your main interface. When you want to record guitar through the 11R, you can hook up it's spidf out to the spidf in of the Fast Track and record into your session that way. |
Why Can't I Record Over My Eleven Rack Track! | BryceJay | Pro Tools 10 | 1 | 03-16-2013 04:15 PM |
Fast Track Ultra 8R & Eleven Rack in PT10, Re-amping not possible | noiseless64 | Pro Tools M-Powered (Win) | 0 | 02-12-2012 10:32 AM |
Fast Track Ultra 8R + Eleven Rack both in PT10: Incomplete operation | noiseless64 | Windows | 0 | 02-07-2012 02:17 PM |
hi there does the fast track ultra rack work with standard pro tools 10? | Corebeatz | Windows | 3 | 01-27-2012 03:37 AM |
New Eleven rack Track | PMcC | Eleven Rack | 16 | 11-15-2010 09:55 AM |
