Time Compression: Shift+Spacebar vs. Plugin
For stretching out the length of a sample (to exactly double it's original time length), I can't seem to get the Digirack Time Comression/Expansion tool to sound as good as when I simply hold down shift and tap spacebar to listen to the sample play back. I know I can just record the output but it seems like a backwards way to do it....are there certain settings i should be using to match exactly the way it sounds when i shift and spacebar it?
Thanks |
Re: Time Compression: Shift+Spacebar vs. Plugin
When you Shift+Spacebar.. you're not using any time compression/expansion... you're simplay halving the sample rate. You can use something like my Header Investigator to change a file's sample rate without affecting the data.
Rail
new time shift plugin by digidesign | peter99 | Pro Tools TDM Systems (Mac) | 14 | 05-27-2007 08:39 PM |
Delete key and Time Shift Plugin | Matthew Steel | Pro Tools TDM Systems (Mac) | 2 | 02-24-2007 02:40 AM |
Time Shift plugin won't come up | theAlien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-05-2006 05:14 AM |
New DigiRack Plugin "Time Shift" issue | Deafeye | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-03-2006 12:32 PM |
Pitch Shift Time Compression | stut5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-03-2003 09:24 PM |
