Signal Routing
Running Mac 10.4.11. LE Rack 002. Just upgraded to PT 7.4. Everything was working fine. Opened session this morning and get this on track output. "the output could not be made active because the output path is currently not available." Everything looks normal in I/O. Would appreciate any thoughts thanks.
Re: Signal Routing
is this session from this same system? what is the track output set to? have you tried resetting the outputs in i/o back to default?
Signal Routing... | krtshadow | Tips & Tricks | 5 | 03-25-2008 06:55 PM |
Signal Routing | patrick_ny | Pro Tools M-Powered (Win) | 1 | 06-12-2006 07:41 AM |
C24 Signal Routing | 1destiny | ICON & C|24 | 1 | 04-19-2006 12:35 PM |
SIgnal ROuting | basktqase | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 09-23-2005 07:34 AM |
SIGNAL ROUTING | cigam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-20-2004 11:53 AM |
