Old 05-14-2003, 11:29 PM
Mike F Mike F is offline
Default Mac gurus Help!! HD initialise problem
just wondered if you've come across this one before:
I have an external firewire drive hooked up to the G4. I buy seagate barracuda's to back up onto.
This time, I put a brand new 40Gb disk in. I get the usual message: "..disk unreadable. do you want to initialise...?
my format options say
"Mac OS standard 127.9Gb"
"Mac OS extended 127.9Gb"
"DOS 127.9Gb"
Question 1: the disk is 40Gb, why does it say 127.9Gb ??
When I choose Mac extended (or standard) & I get "initialisation failed"
Fearing a faulty disk, I took it back to the shop where they ran a test on it which showed all OK
In desperation, I went through the process using "DOS format" The disk initialised, appeared on the desktop as a 64Gb (!!??) drive. I was able to copy data to & from it, all seems ok. Strangely, under mac utilities, it doesn't recognise the disk, but it's there on the desktop!
Any idea what's going on here??
PS I have just bought another new HD, & am faced with exactly the same scenario.
Thanks in advance,
Mike
Old 05-15-2003, 12:39 AM
Rey Mo Rey Mo is offline
Default Re: Mac gurus Help!! HD initialise problem
That's a strange one. I don't know if it'll work, but I'd try booting with a Mac OS CD and using the Disk Utility (OS X) or Drive Setup on the disk.
What OS are you using?
Don't believe everything you think.
Old 05-15-2003, 03:05 AM
sorry, I forgot to mention. I'm on OS 9 [img]images/icons/rolleyes.gif[/img]
Old 05-15-2003, 03:13 AM
linpaws linpaws is offline
Hello Mike,
Maybe this helps: (copied from apple support)
If your hard disk is not an Apple hard disk:
Use the disk utility software provided by the disk's manufacturer instead of Drive Setup.
If you want to initialize your startup disk:
Start up your computer from the system software CD. Open Drive Setup, select the startup disk, and click Initialize.
If initialization fails:
Open the Functions menu and choose Initialization Options. Click the "Low level format" and "Zero all data" checkboxes to select them. Then try initializing the disk again.
If initialization fails a second time:
Test your hard disk for physical damage.
p.s. no mac-guru, rather a search-guru
Paul
Old 05-15-2003, 07:35 AM
soundboy69 soundboy69 is offline
Location: From: Trinidad (Humboldt Co.); living: somewhere between Chicago and St.Louis...
I have a feeling this is a "low-level" format issue. Although I'm curious. Digi says to format using Apple's "Disk Utility"...interesting to see if it'll run sessions or PT...
soundphaRm
Old 05-15-2003, 05:23 PM
after no success with apple utilities, I got onto the seagate web site. One of their recomendations was to try other mac utilities software. I have Nortons, but nowhere does it make reference to initialise or formatting hard drives, although Nortons does see the disk as an unmounted drive.
Am I right in saying Nortons has no format function?? (I would have thought that a fairly obvious & basic utility!)
What other formatting software is out there?
Old 05-15-2003, 06:39 PM
ah ...problem solved, by connecting the drive up internally. Initialised no problem. Back into the firewire drive & all is sweet again.
Still curious as to why it didn't want to initialise via the firewire box - I've been able to do this before.
BIG, MAJOR PROBLEM i7 comp gurus plz help! HDK_Ent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-16-2010 03:12 AM
PC Gurus, again ikke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-10-2004 04:21 AM
Any PC gurus in here? ikke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 25 04-04-2004 06:45 AM
Re-Initialise Hard Drive - Have to re-authorise plug-ins??? DigiTechSupt Pro Tools TDM Systems (Mac) 2 04-02-2003 12:44 AM
MAC Gurus help me out!!! ongaku 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-16-2002 06:30 AM
