Can I record in stereo using the Powerbook G4 mini-jack external audio input?
I use PT Free on a Powerbook G4 and import recorded audio into it through an external mixer. I connect the mixer to to the Powerbook external audio minijack input using an RCA-to-minijack adaptor. Can I record in PT Free in stereo using this configuration, or do i have to have a USB audio interface (Edirol 1-A, for example) with Left and Right RCA inputs in order to record simultaneously L and R stereo tracks in PT FREE?
Thanks in advance for the help! |
Re: Can I record in stereo using the Powerbook G4 mini-jack external audio input?
One more related inquiry: with my current setup I can see a level signal in PT FREE only when the Left Input is selected in the track mixer channel. If I try to select the Right Input there is no signal. Is this normal, or do I have a problem with my mixer?
It's more than likely a problem with your adaptor. Most of the adaptors I've seen are pretty fat and sometimes won't fit completely into the jack. Try swapping R&L (on the adapter) and see if it changes. Better to use a RCA to 1/8" TRS cable and lose the adaptor.
You might want to double-check your software routing setups just to be sure before you spring for another cable though. |
stereo mini to 2 1/4" jack adapter | djcreation24 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-22-2011 06:10 AM |
Possible to disable the stereo mini-jack outlet on a PC? | howie b | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-28-2009 05:30 PM |
Mono input to record in stereo | larrylujack | Pro Tools M-Powered (Win) | 1 | 06-09-2008 06:49 AM |
Mbox mini - stereo input being sent to both R & L monitor | Dr.Oates | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-25-2007 08:03 AM |
MAC audio out jack into 001 inputs - only 1/2 of stereo | Son of David | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-07-2003 02:55 PM |
