001\'s second life
I have a 001 that has been retired from an audio sweetening room. I know I can install it in a windows machine. Am I able to use the 001 as a supercharged audio card? What I mean is I have a computer that needs a good sound card, but won't do any editing. So, if the user opened up a Quicktime video stream, would the audio come out of the 001 like it now does on a cheap, noisy built-in sound card?
Re: 001\'s second life
If it's sound you're looking for, don't waste a 001 on just that... Heck, I'd trade a good sound card to you for your Digi001...
Thanks in Advance, Zetajazz44 |
Second life? It never stopped having a first life! |
The wavedriver for the OO1 is more trouble than it is worth.
Your PC will never recognize the OO1 as a generic sound card. Sell the OO1 on ebay and get a real card or box that can record as well. If you have some ASIO applications, however, the OO1 is a perfect fit. |
copied from http://www.digidesign.com/download/wave/ The Digidesign WaveDriver 6.1.1 is a two-channel, multimedia sound driver that allows third-party audio applications to play back through channels 1-2 of any Pro Tools LE system on Windows XP. The Digidesign WaveDriver is not required to use Pro Tools LE, so it is not installed by the Pro Tools LE 6.1.1 updater. Note: Owners of Pro Tools TDM or LE software version 6.4, 6.7 or 6.9 can install the correct version of WaveDriver for their system as an option during Pro Tools installation, using the box in the installer dialogue that is already checked by default. If you have Pro Tools 6.4 or higher software, you should NOT install WaveDriver 6.1.1. You may still want to download the Digi MME Helper on the page below. Compatibility The Digidesign WaveDriver 6.1.1 can be used on Digidesign-qualified Windows XP systems with Pro Tools LE 6.1.1 installed, or it can be used as a stand-alone driver on systems that do not have Pro Tools installed. If Pro Tools is installed, Pro Tools LE 6.1.1 is required. This version will not work with Pro Tools LE 6.1 or older installed. The Digidesign WaveDriver v6.1.1 can also be installed as standalone if no version of Pro Tools is installed. Supported Digidesign hardware on Windows XP Professional or Home with Pro Tools LE 6.1.1 installed: Digi 002 Digi 002 Rack Digi 001 Mbox AudioMedia III The following programs have been tested with the Digidesign WaveDriver 6.1.1: Microsoft Media Player 8.x and 9 Musicmatch Jukebox 8.0 Nullsoft Winamp 2.91 and 3.0 Propellerhead Rebirth 2.01 Sonic Foundry CD Architect 5.0 Sonic Foundry Sound Forge 4.x and 6.0 Note: The Digidesign WaveDriver does not support Avid Xpress DV or certain other DirectSound applications that require advanced DirectSound capabilities. To add or remove programs, you can use the Digi MME Helper program listed below on this page. Documentation For more information, please see the WaveDriver Usage Guide included with the download. WaveDriver Usage Guide (40 k) Note: The Digidesign WaveDriver 6.1.1 and the Digidesign ASIO Driver 6.1.1 can both be installed on the same system (5.3 versions could not coexist)
Camilo Toledo |
2 001's in 1 pc? | Ruba | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-09-2004 06:27 AM |
Two 001's = 16 outs | hgen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 04-17-2004 08:28 AM |
Can I use two 001's simultaneously? | Moot | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-14-2001 05:36 PM |
Two 001's in the same PC? | Hannon Lane | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-02-2001 09:48 PM |
can i use 2 digi 001's? | blackfire777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-02-2001 06:49 AM |
