Old 03-08-2011, 08:22 AM
jhumber jhumber is offline
Default How do you guys use the noise gate?
On some of the higher gain patches, I get a weird trailing-effect, which I think is the noise-gate doing it's thing.
How do you guys have the noise gate set for higher gain patches? Off completely? Or at what settings?
Thanks in advance
Jordan
Old 03-08-2011, 09:44 PM
TieDyedDevil TieDyedDevil is offline
Default Re: How do you guys use the noise gate?
The trailing effect is the string noise dying down as the gate closes.
There are three things you'd do, in combination, to fix that:
1. Raise the threshold (values closer to zero).
2. Shorten the release time (smaller values).
3. Mute the strings more carefully.
Old 03-09-2011, 02:58 AM
Muzza_Boogie Muzza_Boogie is offline
generally speaking I turn it off... never used one full stop.. must be partial to noise :)
Old 03-09-2011, 07:18 AM
bassmanjazz bassmanjazz is offline
generally i start with the noise gate completely off and try to balance 'response' to 'noise' with my ears, especially if I am playing a part with lots of rest, or what I like to call 'flavor licks'. For rythm tracks that are pretty solid just doing some editing after to remove noise from the 'dead' spots on the track should suffice, slip mode and zoom right in :)
For live use, a gate can take away from performances, especially where long sustained notes are your preference, so use judiciously and get a foot controller or be very good with the volume control on your axe.
11 is an excellent product, can't wait for the exp pack!
Old 03-09-2011, 11:01 AM
stvnscott stvnscott is offline
I've never been a fan of noise gates, so I turn it off. I wish there was a way to do this globally.
Old 03-09-2011, 01:10 PM
ratter ratter is offline
Off.
Where is the noise gate? morganaeddy Pro Tools 9 2 03-12-2012 07:25 PM
Noise gate plug in ksg Pro Tools 9 4 11-28-2011 07:36 AM
Recommend a noise gate and more GtrDude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-04-2009 10:03 AM
Noise Gate Meters Joe Boerst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-13-2007 08:44 AM
Recommend a noise gate. . . or something GtrDude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-24-2003 05:39 PM
