Midi Communication Problem
Hi - I'll cut to the chase!
Midi - Has midi info and is routed to use Reason Audio 1 - Has a reason insert.Output is Bus 1-2. Audio 2 - Input is Bus 1-2. Output is 1-2. It is set to record/standby The first time I load up a song the MIDI Plays nicely. All the indicators move with the music. After I stop playback and restart again it won't work. The MIDI track itself shows activity but nothing on the audio tracks or the software synth. It's as if Protools will only send the signal to the software synth the first run though but won't after that. It has worked fine for me up until today. Anyone have this problem? |
Re: Midi Communication Problem
Davidblake
filosofem
Aaron Mulqueen - 001 HD Native |
Thanks for the reply. That's what I've got I think:
Midi - Reason Track 1 - Reason plugin bus 1-2 Track 2 - Bus 1-2 As I said, it worked the first time but then not again. I didn't think I changed anything in between. |
Davidblake
If you say your routing is correct. Could you post your system details for others to solve this problem. ...and check out this Troubleshooting Thread ...in other words you could try trashing the Prefs and Databases for a start. filosofem
Mic Pre Communication problem! | AlexDC | Pro Tools TDM Systems (Mac) | 3 | 10-01-2010 02:13 PM |
003 rack communication problem... | fab leseure | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-07-2010 03:52 PM |
Communication problem with pre | dubtoc | ICON & C|24 | 13 | 11-18-2008 08:15 AM |
002 fader communication problem | Seattle Guy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 02-12-2004 06:10 AM |
MIDI communication problem | ringrose | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-14-2000 06:46 PM |
