sync issues 002 and behringer ADA8000 in core audio
I've got an 002 on a Mac Pro running 10.4
I've got the Behringer DA for 8 extra outputs connected with an optical cable. The DA is set to 44.1 slave. I'm using Ableton Live, so i'm using the CoreAudio Driver. When I start CoreAudio, it defaults to Optical = S/PDIF, RCA = OFF, and Clock Source Optical (S/PDIF) I change the input to RCA = S/PDIF, Optical = ADAT, and set the Clock Source to Internal. Then I start Live, and all is good. But these settings are never saved. I have to change them everytime? Does anyone know why? Do I need another optical cable going the other way? Are these hardware setting different than those when running ProTools? Thanks in advance, M Schloss |
Re: sync issues 002 and behringer ADA8000 in core audio
(bump)
No one has had this problem? Do you guys need some more information? |
Yes, we are aware of this issue and have logged it for a fix.
For anyone who might be interested, I found a strange fix to my problem.
When I changed the buffer size, it rearranged outputs 9-18. Before, the s/pdif outs were 9-10, and the optical (ADAT) were 11-18. So it looked for sync on s/pdif, which I had to change everytime. After the buffer size adjustment, the optical ADAT outs moved to 9-16, and s/pdif to 17-18. This happened automatically, and now the correct digital outs and sync stay selected. Hopefully I described this alright, and it will help you guys fix the bug. |
Behringer ADA8000 (BLA) | JONK | Pro Tools 9 | 14 | 03-14-2012 02:28 PM |
Behringer ADA8000? | sethbrand | General Discussion | 3 | 02-20-2007 11:58 PM |
sync error with digi002r and behringer ada8000 | hagmanma | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-20-2007 04:16 AM |
Clock sync problems with 001 and Behringer ADA8000 | Gordon keiter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-12-2006 03:32 PM |
connect my M-Audio 1814 to my Behringer ADA8000? | nollynixon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-12-2005 04:34 PM |
