Cue Mix monitoring ?
After setting up a discrete cue mix how does one monitor the cue mix so you can hear what the singer in the booth is talking about. You need to monitor the cue mix before you can make the changes. ie " I can't hear my vocal". How are you guys doin' this?
Re: Cue Mix monitoring ?
We do it by listening to a pair of headphones connected to the same amp that's feeding the artist's phones.
This is much better than listening thru the speakers, as you get to hear exactly the same mix in the same environment as the artist. In our studio, there's a phones-out socket in the control room, next to the engineer, with an on/off switch. Izhar |
Patman,
What I do is set up my cue mix off of a send like normal and then assign the output of the send not only to the cue mix but to an alternate set of ProTools output such as 3&4. This allows me to monitor the headphone mix by hitting the "other ProTools sources button. If you want to hear it through the headphones just use the headphone jack on Control|24. Hope this helps, it sure did work for us. |
Direct Monitoring VS PT Monitoring | therecordinghouse | macOS | 5 | 11-23-2013 05:18 PM |
Record monitoring level different from Playback monitoring level. | sonicflwr | macOS | 1 | 03-09-2012 10:05 AM |
Monitoring through Rosetta vs Monitoring through 003 | Rob0214 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-17-2010 03:02 AM |
Auto Input monitoring / Input only monitoring - Alt+K | AdamPT8 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-09-2010 10:50 AM |
Monitoring 5.1 | [email protected] | Pro Tools TDM Systems (Mac) | 1 | 05-23-2001 08:10 AM |
