Old 06-28-2003, 09:46 PM
GZUZIZLORD GZUZIZLORD is offline
Default Dr. Groove Problems/drum machines in gen.
I have a dr. groove that I work up drum lines on, but when I go to record theres just too much noise. Not only on mine but on other peoples drum machines. I dont know what to do, Ive tried all that I can, and even took it to the local music shop. It didnt seem that bad there, but they couldnt offer a solution. Also in pro tools is there a way to record midi from a drum machine thats synced via midi thru from the keyboard thats synced to pro tools beat clock. I can record midi from my keyboard fine but I dont know if theres even a way to record midi from the dr. groove thas synced to my keyboard.
thanks
Miklo
1 G. Recordz
Old 06-28-2003, 10:17 PM
mentalmusic mentalmusic is offline
Default Re: Dr. Groove Problems/drum machines in gen.
Yeah, I have the Dr. Groove SP-202. It is a little noisy, but I still use it because it has some really great sounds. In fact, between all of the groove boxes on the market, it got rated #1 in the low frequecy category and in the most bang for your buck category.
I usually record with the master volume knob at the 3'oclock position for the best signal-to-noise ratio. And usually when you mix it in with other tracks the noise becomes a lot less noticable.
I haven't used it in quite a while, but as far as midi capability goes, it can only send out 3 midi channels (one for bass, one for drums, and one for "external" in case you are triggering a sampler or something). If you wish to record each drum separately, you have to manually go through and mute all drums except the one that you are recording. You can get the box to do about anything you want it to, but it just takes a little more time the the ones that cost a million times more.
Digi001 * Pro Tools LE v5.2beta * Mac G4 733Mhz * 1.5gb RAM
40gb internal HD * Lacie 40gb firewire HD * Radeon 7000 dual-display
http://www.erikkarter.batcave.net
Old 06-30-2003, 11:53 AM
Cool! thanks.
about that master fader are you going thru a mixer or straight into pro tools?
Miklo
1 G. Recordz
Drum machines nny 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 10-01-2016 02:27 PM
Recording Drum machines with Midi trigger problems NUJUNGL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-29-2008 03:31 PM
Drum Machines WBurrough 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-05-2007 01:45 PM
OT: Groove Agent and drum machines Hogie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-17-2005 06:52 PM
Drum Machines! TiPo General Discussion 7 05-20-2003 01:49 AM
