tracks out of synch / there seams to be a delay . . .
Hello,
When I play back a recording (PT 7.3 - MBox 2pro - xp), the tracks that are recorded sound out of synch. As an example - I'll record the drums (4 tracks) at the same time - in playback, they sound fine. When I add Bass / guitar / whatever . . . it is out of synch with the drums - even though they sound perfectly in synch when the recording is made. I've tried several recordings - & even scaled down to single beats & get the same 'out of synch' situation. Thoughts?? |
Re: tracks out of synch / there seams to be a delay . . .
Sorry - wrong group!
Sounds like you've got some plugins running somewhere that are causing latency, have you checked the delays of each track, if you hold down control and alt and click twice in the little box under the fader in the mixer it will show all the delays for the tracks. If there's some with delay you will need to nudge the tracks around to get them back in sync. PT LE unlike just about every other sequencer doesn't have delay compensation, rather annoying at times. Hope this helps.
ASUS P5k, Win 7, RME Multiface Macpro, 10.8.3, Digi 003 Profire 2626 PT 10.3.6 |
Tracks Out of Synch | [email protected] | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-02-2011 08:25 PM |
tracks out of synch / there seams to be a delay . . . | sambeau | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-30-2007 11:21 AM |
Ok, now 6.7 seams to be ok... | Tubz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-01-2004 04:44 PM |
Bounce to Disc/Low Latency Off, but Audio & Midi Tracks out of synch... | Roy Howell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-15-2001 01:12 PM |
Re-Synch Audio Tracks? | gbogart | Digidesign Hardware & Software | 5 | 02-12-2001 06:07 AM |
