Old 05-29-2021, 05:16 PM
[email protected] marcom1@comcast.net is offline
Default 1st gen Digidesign 192 interface with HDX ?
Hi All,
I’ve got the 1st generation digidesign 192 I/O and wondering if it will work with the latest HDX Protools card. I’m currently running the first gen PCI cards (HDcore + 2accel cards) with it. Ive recently built up a new PC and looking to get a newer HDX card to put in it, and hoping the 192 I/O will work. Would appreciate any confirmation either way. Thanks,
Marco
Old 05-29-2021, 05:57 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Default Re: 1st gen Digidesign 192 interface with HDX ?
My understanding is that it will be fine provided it works. Bobby Lombardi told me the only reason they stopped officially supporting them was because some of the parts were no longer available.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 05-29-2021, 07:29 PM
Third Eye Studios Third Eye Studios is offline
Originally Posted by [email protected] View Post
Hi All,
Marco
I recently made a similar move, and all is well. I have 3 x 192's, no issues.
Old 05-29-2021, 09:54 PM
JFreak's Avatar
JFreak JFreak is online now
Yes it works, but Avid will not provide firmware updates to DigiDesign boxes, should they need one. Latency is also different than Avid HD interface, but it is not a problem with PT which knows how many samples to compensate. But good to know if you use 3rd party boxes that emulate either 192 or HD interface. Even then it is not a problem, if you use inserts the proper way, but routing out of 192 and in to HD may cause phasing.
Janne
Old 05-30-2021, 05:46 AM
Hi there, thanks for the insight! Not sure what you mean when you said “Routing out of the 192 into HD” does that mean that if I re-amp a guitar signal using an analog-out channel that it won’t be sample accurate and in time with the recording? Can you give an example of the potential issue? Thanks ,
Marco
Old 05-30-2021, 06:52 AM
JFreak's Avatar
Marco
The proper way to use hardware inserts (as in re-amping) would be setting it up in i/o setup and that requires matching output and input numbers. Say, 192 output 8 and input 8 pair would be set up as hardware insert and used like a plugin in the mixer window. This will be latency compensated.
The weird way some are still using is setting just any output, say output 7 and then re-recording the re-amped stuff to some other input, say input 6. This most likely introduces latency problems and is also harder to use than hardware insert..
Janne
Old 05-30-2021, 08:35 AM
gives's Avatar
gives gives is offline
If you are interested, I have a mint condition Avid HD I/O 8x8x8 Audio Interface which I had replaced a 192 interface. DM me if you are interested.. It's up on Reverb.com and priced great! It also supports 32 bit audio. I upgraded my room to a fully loaded MTRX interface for Dolby Atmos, so that is the only reason I got rid of it. Latency is a lot better than the 192 btw.
https://reverb.com/item/39234105-avi...ce-2013-silver
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
FS: Digidesign 96 IO Interface Justin1524 Buy & Sell 1 10-13-2014 10:18 AM
Digidesign 882/20 interface - $50 Dopamine Buy & Sell 0 03-15-2013 02:54 PM
Digidesign 96i Interface Oliver M Buy & Sell 0 11-20-2012 05:10 AM
Digidesign MIDI Interface ikke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-06-2004 04:41 PM
Digidesign 442 and Digidesign Amadeus Interface Audioprof Digidesign Hardware & Software 1 04-05-2004 10:58 AM
