  #111
Old 03-31-2018, 07:52 AM
grayter1 grayter1 is offline
Default Re: 2018.3 Running Very Well Here.
Originally Posted by JFreak View Post
Carbon Copy Cloner -- just clone your system drive in working condition and you have a copy available to boot from if you're too busy to clone it back to your system drive.
NVIDIA updated the display driver this morning and I'm back up running. Now I'm off to purchase Carbon Copy Cloner...
tg
Mac Studio (2022) M1 MAX / 64GB / 2TB HD / macOS Ventura 13.6.5 / RME BabyFace Pro FS / SSL UF8 + UF1 + UC1 / Roland SYSTEM 8 / Kontrol S61 mk3 / Pro Tools Studio 2024.3 / Nuendo 13 / Reaper 7 / Komplete 14 / Omnisphere / Keyscape / Trilian / V Collection X
  #112
Old 03-31-2018, 08:25 AM
Emi's Avatar
Emi Emi is offline
Originally Posted by TOM@METRO View Post
Anyone running this at higher sample rates?
Running at 96 and 192 here with good results.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
  #113
Old 03-31-2018, 08:26 AM
tg
And make sure the drive you backup to is not connected or at least turned on all the time. Less of a chance on it getting mucked up. Neat thing with CCC is you can set it to work on a schedule as well as manually. CCC can also do what they call a 'safety net' which if you're backing up to a drive you've backed up to in the past it will put the files that have been replaced by new versions in the safety net so you can go back if you so choose.
Jack
QAPLA!
  #114
Old 04-01-2018, 07:02 AM
TOM@METRO's Avatar
Thanks, Emi.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #115
Old 04-01-2018, 11:30 AM
climber climber is offline
Originally Posted by Ray Lyon View Post
A couple of upgrade questions...
When I upgrade from 12.8.1 to 2018.3 can I rename the older PT app icon to 12.8.1 to preserve it in case there is a problem? Will the older version launch as is with no problem even though the new updated HD Driver is installed?
If I have two or more older versions on my Mac can I go back to any of the earlier versions by launching the older version directly from the Applications folder?
Thanks for your help!
Yes and yes, Mac only...
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
  #116
Old 04-01-2018, 09:33 PM
Ray Lyon Ray Lyon is offline
Thank you Al!
  #117
Old 04-06-2018, 04:43 AM
StillHollow StillHollow is offline
And for us Windows 10 users, what is the best AND easiest Carbon Copy Cloner alternative to use ?
  #118
Old 04-06-2018, 10:04 AM
The Weed's Avatar
The Weed The Weed is offline
Macrium Reflect works very well for me and has great options. Others like Paragon.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
  #119
Old 04-06-2018, 02:35 PM
LightWing's Avatar
LightWing LightWing is offline
Only using it half a day so far...not bad.
See my possible PT 12.8.3 and/or Xpand!2 BUG thread I just started.
Patrick
www.LightWingStudios.com
Musical Instrument Protection Accessories...Made In America.
Dell Precision T7910, Dual Processors (total 20 Cores), 128GB RAM, 4 @ 2TB SSDs, 1 @ 4TB HDs, Nvidia 2GB Dual Monitor Card, Dual LG 48" TVs used as Monitors, Arturia 88 Midi Controller, Black Lion USB Audio Interface, Mackie HR-828 Monitors, Katana Head, Fishman Triple Play, Win 10 Pro, PT 2023.3 Studio, only the Plugins I NEED, WAY TOO MANY Guitars...and an AMAZING wife!
AxeShield HD, AmpShield HD, KeyShield HD, AxeSak, AxeGlove, AxeCap & PedalShield
  #120
profdraper profdraper is offline
In my experience, there is *nothing* like CCC for Win10, unfortunately. If you are familiar with CCC then I suggest you have a scan of the relevant Win10 manuals for backup software before purchase and that will be immediately clear. eg:
In a scenario here using both system disk back up, plus several data SSDs and a RAID - variously for video, audio, sound libraries, other documents etc.
  • CCC is very fast to make back-ups, especially once beyond the initial full. The Win equivalent is usually not by comparison.
  • CCC can check all backups very quickly and then make updates to each image *simultaneously*; Win10 equivalents are much slower and can only update one image at at time, one after the other.
  • Biggest issue for me: Win10 software assumes some kind of office model and insists on setting up scheduled times for backup, like at 5pm when you 'go home' 'from work'. Yeah, right ....This is also quite laborious /boring to set up because each and every backup plan has to be manually fiddled with, timed disk schedules to avoid each other etc.
  • With CCC: for data disk backup 'schedule' I use 'when source or destination is reconnected'. This means that when I simply turn on my external JBOD array, CCC sees that and does quick, simultaneous backups at a time of my choosing, or in combination with regular scheduled backups. Some Win10 software provides for what appears to be similar as 'on event' commands but in my experience this is both poorly documented and unreliable.
FWIW, the two most consistently, highly rated Win10 backup solutions are 'Acronis True Image' and StorageCraft's 'Shadow Protect'. But they work as per the above comparison.
MacPro 7,1 Big Sur 11.2. 16 core, 2TB, 192GB, Vega II 32GB. OWC Thunderbay 6, RME UFX+, UAD-2 quad PCIe, Decklink MiniMon 4k, Sonnet M.2 4x4. Dell U3419W & BenQ SW2700PT. FaderPort 16, Komplete Kontrol S61, Nuendo, Wavelab, Pro Tools Ultimate, Logic, Ableton Live. FinalCutPro, Resolve Studio.
Going from PT 6.4 to 2018 CDB Studios WI Getting Started 7 02-25-2018 04:32 AM
Issues running PT 12.x and 2018 on Late 2012 i7 iMac 27" 3.4Ghz 32GB Ram foxes Pro Tools 2018 26 02-18-2018 11:44 AM
Xpand!2 2018 & Air Instruments 2018 lgreen100 Pro Tools 2018 16 02-15-2018 05:01 PM
Pt 2018 os x 10.12.6 Stys64 Pro Tools 2018 5 02-06-2018 08:14 AM
