Hide Mix - Show Edit Weird Behavior?
I noticed that if I open a session and have the mix window open then click Hide Mix, PTLE will attempt to shut down. I'm sure in 5.1.1 that this would have resulted in opening the edit window. To get around this you just have to Show Edit before you ever use the Hide Mix button. No big deal but I don't think it should try to close PT.
Re: Hide Mix - Show Edit Weird Behavior?
actually, i experienced this behavior in 5.1.1. if you tell protools to hide the form that is visible, and there are no other (mdichild) forms to display, protools assumes that you want to close the program entirely. i have mostly adapted to this behavior, as i no longer tell protools to "hide" the form i don't want to see. instead, i tell it to "show" the form i do want to see. see?
what i do in a session is, maximize the window (either edit or mix window, it will maximize both), and use control +/= (left of backspace) to toggle between the two windows. that way your window is at its biggest, and going between them is a keyboard stoke away..
You have to have at least one window open at all times or the session tries to close down. This happened in 5.1 as well. I keep them both open, but postion them so that I can click on an edge of either window to go back and forth.
ASUS A7N8X-E Deluxe MD Athlon XP3200+2.20GHZ Corsair XMS PC3200 400MHZ 1GB WD EIDE 10GB WD EIDE 250GB XP Pro SP1 ProTools LE 6.4 |
hide/show tracks in edit window? | fransmo | Tips & Tricks | 5 | 07-16-2016 06:55 AM |
Pro Tools Show/Hide behavior in MIDI editor has changed | malvicus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-16-2010 06:25 PM |
Show Hide Mix Edit Help | FedericoF | Pro Tools TDM Systems (Mac) | 3 | 02-06-2010 06:05 PM |
Weird Track Show vs Hide while Importing Session Data in PT8 | acacia | Pro Tools TDM Systems (Mac) | 2 | 06-02-2009 01:54 AM |
Can I Show/Hide Edit & Mix Windows Sperately? | Johnny2Laps | Pro Tools TDM Systems (Mac) | 1 | 02-14-2005 04:24 PM |
