Regions to small... PLEASE HELP!!!
So i recorded a band the other day and i did vocals basically line by line so there were tons of very small vocal parts creating the longer vocal lines, but when i went back into the sessions to mix the songs a message came up saying that some regions were delted from the timeline because they are too small. So the result is that all of my vocals have been deleted from the sessions. Does anybody know how to change this setting? Any help is appreciated. Thanks
Re: Regions to small... PLEASE HELP!!!
Had the same problem about a month ago. I'm guessing you're on 6.4--I was. Good news is your files are probably there. Look for them in the 'audio files' folder of that session. ( I can't remember exactly, but I think they've retained the tracknames...) You'll have to identify them, then import them into the session and rebuild tracks and playlists, if any. It's a pain, but it's a road back. The solution for me was to upgrade to 6.4cs9. It includes a fix for that particular problem.
Hope this helps. grae |
6.4 CS9 also fixed that problem for me. You should ALWAYS consolodate your final track BEFORE closing your session. Just duplicate your playlist and make sure your edits are smooth. It is fast, and sometimes regions go missing or get bumped, or ect,
I always consolodate my master files at the end of the day and back them up, that way if a strange act of god, or digi happens, you butt is saved. You can also use the "Save Session Copy in" command and just copy your EDL, but it may have the same problem as the original session. Hope this helps.
Sign up for all things....AWESOME! Kris May the music move you |
yeah, i just installed the cs9 but it didn't do anything to help, so i am currently trying to piece my sessions back together. This problem is just really lame.
Not aligning to the grid when duplicating loops / regions. Off by small smaples. | xstortionist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 03-11-2011 06:47 AM |
Regions truncaded or deleted *files too small?* | garnoil | Post - Surround - Video | 13 | 09-23-2009 02:17 PM |
realtime pitch (without time correction) in PT8? + putting audio regions into regions | fonografist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-07-2008 11:15 AM |
Regions to small??? | jeffking | Pro Tools TDM Systems (Mac) | 0 | 03-12-2008 06:23 AM |
Help find small sliver regions | postman56 | Tips & Tricks | 2 | 10-20-2005 01:29 PM |
