Fallen, can\'t get up
Hey all,
Was having some trouble with PT LE, so I re-installed. Everything's fine with PT now, but my MP3 player won't work (Sound Jam MP), and I keep getting "Error -200" when I try to hear Quicktime movies (the visual is there, but no sound). Any thoughts? I'm missing the jukebox! |
Re: Fallen, can\'t get up
No love?
Without knowning anything else about your system, I am guessing an extension conflict is causing you problems:
-Open the Extensions Manager Control Panel. From the selected set pop-up menu, select “OS 8/9.x base” click on “Duplicate Set" at the bottom of the window. Name the set whatever you like. Enable the following extensions and restart the computer: -DigiSystem INIT -Digidesign Direct I/O (required with DSI 5.0.1 and later) -Digidesign DSP Manager -Digidesign Stream Manager (only if using DirectConnect) -Open Music System -USB Floppy Enabler (only for B&W G3 and G4's) Brent |
Thanks for responding, Brent.
I re-installed the system software (in-place), and got the MP3 player working...however, now I'm not able to get my MP3s to play through the 001 (which I think is a common problem that's been covered here elsewhere...it's like I was 'getting away with it before', and now I'm in the same boat others are). I'll look at those other patches....but if you have a quick response (re: playing MP3s [using, say, SoundJam], through the 001, please fill me in). Thanks again. |
You probably already know this but just in case . . . .
Is "Digidesign" selected (not "built in") in the sound out window of the sound control panel? If it's not there you hae to enable the extension. I checked my extension set and I have Digidesign Output drivers, Digisystem Init, Digidesign DSP Manager and Digidesign I/O enabled, but not the extension that says simply "Digidesign". Running 8.6 on B&W G3. Soundjam works fine through Digi. Good Luck Bob |
Hey Bob,
I tried to select "Digidesign," but no go...I didn't know about the extension situation, though...I'll give it a shot when I get home. Thanks for the input, EC |
Fallen Art | iamstudios | Post - Surround - Video | 6 | 02-24-2007 09:55 PM |
"Fallen Art" and BAFTA | Kuba Pietrzak | Post - Surround - Video | 4 | 02-20-2006 10:14 AM |
I've Fallen & I Can't Get Up!! | The Waterboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 20 | 11-15-2004 07:27 AM |
I've fallen and I can't get up..... | Keith Kelly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 11-29-2002 04:54 AM |
For Fallen Comrades on 9/11/01 | billbo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 09-12-2001 10:40 PM |
