Digi 003+ Pad not working with DI/Line in
Hey guys,
just registered as I have this problem. The Pad doesn't work with DI/Line in, but when I use the mic in the pad works perfectly. Is this a Firmware issue (11.0)? Or is this normal. The manual says it should work with Line in or Mic in. Other than that everything seems to work fine. I am using 10.6.8 and Logic 9.1.8 Thanks |
Any Digi 003+ users around?
Hey guys,
I've been searching quite a while with no answer. Could you check if the Pad on your Unit works with the DI/Line Inputs. Thanks |
Re: Any Digi 003+ users around?
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey Alesis Masterlink, Alesis Adat LX20, , Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon, Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric. http://www.johnackermusic.com/ [email protected] Live and Let Live |
My pad works fine with the mic inputs but doesn't work when using the Line in/ DI with a guitar. The manual says it should work, a tech said to me the manual is wrong. So I wanted to know from a user if this works on their unit.
ah man..just to confirm - do you have the 003 or the 003+ ?
so the one with the 4 mic pres? I have the one with 8 mic pres
Didn't know they made an 003 with 8 mic pres. Do you have the 003 console?
Sent from my iPhone using Tapatalk.
Line Ins not working on project mix | Infiltrator | Pro Tools M-Powered (Win) | 0 | 12-12-2010 12:58 PM |
Mic Pre / Line input not working! | danoan522 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-04-2009 08:22 PM |
003 line in 7 & 8 not working... | andrew_oc42 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-19-2009 04:49 PM |
PT M-P 7 + Line 6 GuitarPort...Have It Working? | Light Wing | Pro Tools M-Powered (Win) | 3 | 02-25-2006 06:44 AM |
Digi 001 Line in #3 and #4 not working - advice? | justincousin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-11-2005 09:37 AM |
