Old 02-24-2012, 08:34 AM
phab76 phab76 is offline
Default Power Amp + Cab gear (Atomic Amps)
Hello DUC,
I'm looking for a Power Amp + Cab Tube based solution for my 2 preamps:
- My eleven rack (obviously)
- My AMT Electronics Tube Preamp
The only vendor I know is Atomic amps (which looks great).
But before considering them I would like to know is there are other Tube
Based Solutions.
IMPORTANT: I know there are a lot of Solid State / P.A based solutions for ER, Axe FX ... but I want tube (matter of taste and for my SS-10 tube preamp).
BUT: If you have good experience with non tube based Amp feel free to give your advice.
Cheers,
Phab
Hardware:
Gygabyte P55UD4 Core i7 860, 16Go GSkills, SSD/SUB3/SATA2
Software:
Seven 64bits SP1 Eleven Rack fw 2.01 PT 12.4, EZDrummer 2, Guitar Pro
Ibanez RGIR27E BK, Mayones Setius Pro Lizard, Ibanez S470SOL & Washburn N2 (All Duncan Pickups), Fender '78 Acoustic
Other:
AMT SS-10 Valve Preamp, Cry Baby From Hell, Boss GT-3, Digitech Whammy WH-4, iSP Decimator G-String, MXR Custom BadAss OD, Distortion, TC Electronics Flashback
Old 02-25-2012, 09:59 AM
aaron.ferrer aaron.ferrer is offline
Default Re: Power Amp + Cab gear (Atomic Amps)
Carvin TS100 is a cheap tube poweramp you can buy easily.
VHT 2/90/2 is popular, and you can find mesa 2:50/2:90's all day long online and at HC.
For SS, ART SLA series are popular, and only 1U, and the Matrix GT800 is 800 watts in a 1U package. The Rocktron Velocity also gets good reviews for being tubelike.
Old 02-27-2012, 11:56 PM
Thanks but this is a Power Amp + Cab setup up.
I was looking for integrated Power Amp + Cab IN ONE ENCLOSURE.
Like Atomic Amps for example.
Hardware:
Software:
Other:
Old 02-28-2012, 12:52 AM
Power Amp + Cab means different things to different people.
In this case, I don't know any other manufacturers that do what Fractal does with Atomic, and if they did, I'm sure it would be popular by now.
Why not just get a tube combo amp with a series effects loop and plug the eleven rack into that then?
XiTone makes Coaxial powered cabs for modelers, but they are solid state. However, they are getting pretty good reviews among Axe Fx users. The Power Engine is also meant for modelers, but is also SS.
You could always build a poweramp into one. I saw an axe Fx built into a cab with crown amps on the bottom.
Old 02-28-2012, 06:38 AM
Muzza_Boogie Muzza_Boogie is offline
Default
They look pretty good actually!
I see that atomic will be bringing out a coaxial cabinet soon too!
Sent from my iPad using Tapatalk HD
Old 02-28-2012, 08:17 AM
Some posted THIS a couple weeks ago and it is a power amp+cab combo. I don't see that it is a tube power amp however so it may not be what you are after. The premise behind this is that the preamp or modeler does all the tone shaping and the power amp and cab do the "heavy lifting" but do not further color the sound that was dialed in on the preamp or modeler. In other words if you plug you preamp or modeler directly into a recording system or console, that should be the same sound coming from this unit. This way, any cab emulations you use will be preserved and used.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 02-29-2012, 01:24 AM
It's a good option, and does have some EQ options on the input, so, almost like a global EQ.
Scuffham Amps S-Gear Rosco1969 AAX Plug-ins 8 03-09-2014 11:40 PM
Would this UPS (Uninterrupted Power Supply) protect and power my gear? D_Japan macOS 4 07-24-2011 04:23 PM
How much AC power do I need? How many amps? WildHoney Pro Tools TDM Systems (Mac) 21 03-14-2009 12:50 PM
POWER AMPS graveleye 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 09-30-2002 04:30 PM
What Power Amps Y'all Using? Brent Hahn General Discussion 15 07-26-2002 12:43 AM
