Audio Files Not Deleting Permanently
I'm trying to delete audio files permanently from the Regions List. I select unused files and then delete - Remove and Delete Permanently. It tells me I "can't delete them because some regions are still active. Do you want to delete anyway" - I say yes. But the files I don't need are still in the audio folder. Why are the files I don't need still active? I'm to the point that I physically remove audio that I don't need from the audio folder. Thanks.
Re: Audio Files Not Deleting Permanently
It could be that the files which are in your audio folder are not in your region list and therefore are not effected by your attempts to remove them.
If you had 'removed' (not deleted) some files previously, they would remain in the audio files folder. You may have files in that folder from other songs or other versions of the same song, it's hard to say. A quick check might be to rename the files in the audio folder and see if it's in the region list. My guess would be that these unwanted files are not in the list.
God Save Mrs. Mopp |
Deleting Audio Files | suhrmesa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-11-2004 08:47 AM |
Be careful deleting Audio files.... | Roy Howell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 02-05-2003 10:24 AM |
Permanently "DELETING" files from HD | Sabe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 12-17-2001 11:58 AM |
Renaming and/or deleting audio files | davidp158 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 07-05-2001 09:44 AM |
Deleting unwanted audio files | markert | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-25-2001 12:29 AM |
