Old 01-25-2009, 10:03 AM
Mac88s Mac88s is offline
Default Loop Record/pre roll
I'm creating multiple playlists with loop record which is a nice new feature. However, is there a way to set pre roll so that when it loops back for a new playlist that you don't start where the punch in is? For example when it loops back around it goes back to the pre roll start to set up the next playlist instead of where the recording starts.
Old 01-25-2009, 10:11 AM
lwilliam lwilliam is offline
Default Re: Loop Record/pre roll
Nope. It's a nit-pick of mine as well.
It's a feature request that could probably be implemented as a preference (pre-roll active in loop record). As a work-around, I simply start the loop early enough to give me a "pre-roll" and then adjust the region afterwards.
Larry
PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins.
Old 01-25-2009, 10:25 AM
Wow! That does seem odd that PT doesn't have that. Yup, I was doing what you're doing too. Thanks.
punch in loop pre roll pinnacle Pro Tools 10 4 09-14-2012 03:19 PM
PT8/7 Pre/Post roll in loop record mode question - is there a bug or is it normal? bukman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-07-2011 06:07 AM
Make PRE-ROLL stick in each pass in loop record mode? el matador 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-23-2008 03:46 PM
Pre-Roll on loop record / need Preroll on each tak CisumBlue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-23-2005 04:25 AM
Pre/post roll in loop recording 6X 2 Pro Tools TDM Systems (Mac) 1 10-23-2001 10:44 AM
