Working on multiple projects together
Can I just confirm that it's impossible to have multiple PT (LE) projects open at once? Is this any different in HD?
I sometimes work for a radio breakfast show where you need to keep hopping between at least three different projects - they use Nuendo which allows you to Shift+F6 between different open projects, but "steals" the resources from all the but the one in focus - hitting a button restores rescources to any chosen project. Many radio stations where I am likely to do freelance work use PT (mostly HD but also LE) systems but would I be forced to keep opening and closing single projects in this scenario? |
Re: Working on multiple projects together
Hello. Yes as spkguitar mentioned, Pro Tools can only have one session open at a time. However you may be able to have some way around this issue. First off and simplest, if you know ahead of time which sessions you need access to you can simply consolidate all three sessions into one session that contains everything and just navigate down the time line with markers as needed. However, if the sessions you need access to come up at random or with little advance notice, another way is to Import Session Data. That way you can import the tracks that contain the audio you need from the session as the need arises. Yet a third option nowadays is to create Region Groups. This is probably simpler, faster and more efficient that Import Session Data. Create Region Groups in all your sessions where you may need to pull material from. For example, create a region group of nature ambiences, SFX, and Foley from all three different sessions, etc. With the click of a button you can import everything and mix and match as you need. As things are needed, simply import the required Region Group(s) into your session and all the necessary audio will come along with it. Good luck.
froyo |
Multiple drive: OS, software and projects | The Miff | Windows | 4 | 08-31-2012 12:57 AM |
A simple way to work with multiple projects | frenkelon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-25-2011 07:09 AM |
Working on collaborative projects..How do you xchange files? | heybluez | General Discussion | 0 | 03-16-2007 08:59 PM |
Import multiple OMF projects. | David Taylor | Post - Surround - Video | 2 | 09-27-2004 12:49 PM |
What Projects Is Everyone Working On??? | CraigD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-25-2004 10:30 PM |
