#861
Re: PT Performance
New Intel system:
Asus P4C800 Deluxe (Intel 875 chipset) Intel P4 2.8ghz/(800fsb) CPU 1024 MB Corsair XMS 3200 DDR (2x512) WD Raptor SATA 36 G (OS drive) WD 80 G IDE /8MB buffer (Audio Drive) XP Home Edition Antec 430 True Power PS 32 tracks + 12 aux @128 buffer (44.1/24) If the drives are reversed, and the SATA Raptor drive is used as the audio drive and the WD 80 G IDE drive is used for the OS, then I receive the following results: 32 tracks + 14 aux @128 buffer (44.1/23) If "write catching" is disabled on the SATA drive, then I am able to add another 4 tracks, although it's painfully slow on the last two: 32 tracks + 18 aux @ 128 (write catching disabled) Upgraded AMD system: Asus A7N266-VM/AA (original nForce chipset) AMD 2400+(266fsb) CPU 512 MB Crutial 2100 DDR (2x256) WD 40 G HD (OS drive) WD 40 G HD (Audio drive) XP Home Edition Enermax 365w Whisper PS 32 tracks + 2 aux @ 128 buffer (44.1/24) 32 tracks + 8 aux @ 2048 buffer (44.1/24)
John-Q6600,GA-EP35-DS3P, Zigmatec S1283: 235 D-Verbs @ 2.4 ghz |
#862
Re: PT Performance
I have re-tuned the Athlon XP system with new drivers/bios and disabled my onboard sound card and got 32+11, previously was 32+5 (digi002). |
#863
Re: PT Performance
Haigbabe, I have the Digi 001.
Booyah, I also am curious and thinking about swapping drives. I have a copy of Ghost. So, I should be able to put a drive image copy on the IDE drive. Just don't know if it will boot OK? Anybody have experience in this with XP? If so, all I have to do is go into the Bios and change the IDE drive to the boot drive and I will be up and running. Then I can easily use the Raptor for audio. Just not sure how XP will respond to this maneuver.
#864
Re: PT Performance
XP responds to this nicely so long as your SATA drivers are installed and working, its all about the bios boot sequence.
#865
Re: PT Performance
Using the SATA drive for audio (instead of OS)in my setup looks to improve performance by 2 tracks. I went back and edited my original post.
#866
Re: PT Performance
Nice system you got there!. |
#867
Re: PT Performance
In a totally shameless effort to get a few more tracks, I used minimoog's trick- disable "write catching." And it worked pretty good. Got another 4 tracks, but it was so slow at 32 + 18 that the counter updated only 4 times in the 60 second test: at 31 sec, 43 sec, 57sec and 1 min 11 sec. I could hardly believe it could keep going. I finally stopped it after 2 minutes. I re-edited my original post with minimoog's "enhancement" and added this result.
I then tried 32 + 19 and got the error message "Running out of CPU and Stop tormenting your computer!" On my drive disabling write catching slows down the write speed from 45 MB/s to 7 MB/s and reduces CPU usage from 10-12% to 2%. I used the Norton Performance Disk test to get this info.
#868
Re: PT Performance
Just set up the new Studio-Beast. This is the straight out of the box test the only tweak was setting the CPU usage to 85%.
Here's the beast: PT 5.3.1 - Digi001 Win XP Home MOBO - ASUS A7V8X-X CPU - Athlon XP 2700+ RAM - 1 GB Micron Drives - 1 WD 60GB 7200 RPM HD - two partitions Tracks - 32+14 Buffer - 1024 Pretty happy with the performance so far. I have a second IDE 7200 HD that I'm going to use for the wavs. Not sure how much of a difference it'll make. [img]images/icons/cool.gif[/img] |
#869
Re: PT Performance
Way to go here on the new system though. Allen [img]images/icons/wink.gif[/img] |
#870
Re: PT Performance
Just upgraded my computer yesterday. Here are my results. I'm pretty happy with what I got I guess. I think it's probably plenty adequate for what I need. I haven't done any XP tweaks or anything.
PT Version: 5.3.1 - Digi 001 Win XP Pro Tracks: 32+10 MOBO: Intel D845GEBV2 CPU: P4 2.66 Northwood RAM: Crucial 512MB DDR PC 2700 Drives: 2 x IBM 7200 RPM IDE |
Macbook benchmarks/Davec Tests..... | ArtGarceau | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-31-2007 08:34 PM |
24/96 davec tests? | Tyler Crawfprd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-15-2006 02:06 PM |
Davec I,Davec II Tests Both Downloadable Here | davec | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-27-2005 07:45 PM |
hey.... what about the MAC DaveC tests? | JonnyGinese | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-16-2005 01:02 PM |
Results from Davec tests | SEBJOERG | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 01-29-2002 11:53 AM |
