5.1 PC Connections
I am setting up a 5.1 system with my PC and I will be encoding for Dolby Digital I am not sure what is the standard layout for my I/O ( I still need to switch back to Stereo mixing) SMPTE/ITU Layout 5.1 Dolby Digital Monitoring or Film (Pro Tools Default) 5.1 Monitoring Connections.
Which one??? or does it matter Thanks |
Re: 5.1 PC Connections
I think it doesn't matter that much in the end, it's only about monitoring and you only need to to take care about how you route the correct output to the correct speaker. I have my outputs on my 192 I/O distributed as 'Film' routed to a Grace Design m906 (I do not use the analog section of my Pro Control) and from the m906 to the speakers.
If I would like to change the system to SMPTE/ITU Layout 5.1 Dolby Digital Monitoring I should reroute the outputs from my 192 I/O to the m906, that's all. In case of using the analog section of the Pro Control, it is just the same, choose a setting and route accordingly...
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins |
Hi
I have a pro control and use an SPL2489 monitoring controller. I connect the D sub from the 192 to the SPL. The only setting that works in this instance (due to being confined by the dsub) is the DTS/Procontrol layout. This works well for me as 1&2 are L and R in both instances - I just turn the C Sw Ls Rs outputs off to mix in stereo. I got all concerned about track order for dolby E, but either the Neyrink broadcast plug will re-order your files, or the dolby boxes will reorder the stream before it encodes - so it really is no problem. Within the session Protools records 5.1 in its own fixed way on a track and you have no control over the order. Get familiar with your I/O set up page as having sub paths correctly set up really eases life in 5.1. cheers
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
Connetions connections connections | Maxaudio | General Discussion | 3 | 09-28-2011 08:50 AM |
Can you use the SAS connections,,,,,, | pianosound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-14-2011 12:56 AM |
Connections? | Mainstream | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-23-2011 05:58 PM |
Need help with 192 i/o AES connections | losttimestudios | Pro Tools TDM Systems (Mac) | 3 | 08-16-2004 03:13 PM |
TDM Connections ??? | Suz | General Discussion | 1 | 09-17-1999 05:22 PM |
