Old 11-08-2015, 04:23 PM
john1192 john1192 is offline
Default PT 12.3 kontakt ONLY so far commit issue
just found a possible bug .. in kontakt ONLY .. .. when you commit a track and then undo .. when it comes back you have to reset the midi input or it does not play the midi notes .. even though the assignment looks correct ..
i tried same thing in Velvet and it is fine ...
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 11-09-2015, 12:05 AM
H-Musikk H-Musikk is offline
Default Re: PT 12.3 kontakt ONLY so far commit issue
I experienced the same on PC yesterday...
Regards
www.h-musikk.no/english.html
Norway
ASUS X99-E, Intel Core i7-6850K, Noctua NH-U9S, Corsair Vengeance LPX DDR4 2133MHz 16GB, Samsung 960 EVO 250GB M.2 PCIe SSD (System), Samsung 850 EVO 500GB 2.5" SSD (Data), Samsung 850 EVO 1TB 2.5" SSD (Sample), WD Desktop Black 1TB 3.5" (Audio), Gigabyte GeForce GTX 1060, Corsair RM750x 750W, Samsung 34" LED Curved, Windows 10 Pro 64-bit, Lynx AES16e, Aurora 16, Cakewalk by BandLab, Pro Tools 2021
Old 11-09-2015, 05:11 AM
mdvirtual mdvirtual is offline
Seeing the same thing here in Windows 7, hopefully they address this in the next point release.
I'm liking the commit and drag MIDI to audio features otherwise, and 12.3 feels solid so far. Didn't have a chance to push it too hard over the weekend but I'll be putting it through its paces this week on a documentary score.
Michael Damon
Composer/Sound Designer
Virtual Productions
PT Ultimate, i9-9900k, 64GB RAM, Gigabyte Aorus Ultra MB, Sapphire Radeon RX580, Windows 10 Pro, Fireface UFX
Old 11-09-2015, 11:15 AM
i tested 12.3 and kontakt 5.5.1 in mavericks 10.9.5 and it is the same thing ..
and not just Mac but Windows as well .. not sure if this is Kontakt or 12.3 issue ... or a combo issue ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 11-09-2015, 12:20 PM
connor@@vid's Avatar
connor@@vid connor@@vid is offline
I cannot reproduce this here with Kontakt 5.5.0 (which appears to be the latest AAX version installed with 5.5.1 unless I messed up install...)
In the meantime, can you guys PM me links to session files. No audio needed, and you can remove MIDI content as well if you like. Just need the tracks themselves as they are in sessions where you are reproducing this.
Old 11-09-2015, 12:23 PM
i started with 5.5.0 and it happened there .. i updated to 5.5.1 to see if it helped me but it did not ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 11-09-2015, 01:42 PM
Hi Connor, thanks for jumping in. Just PM'd you a session saved in various states of commit/undo.
On my windows system a Kontakt 5.5.1 instrument track consistently loses its MIDI routing following a commit and undo. Interestingly enough the routing is not greyed out as it had been with the MIDI routing bug in PT11. All looks normal in the instrument pane, and if I drill down and click on the MIDI channel the routing is re-established. Also, if I close and reopen the session the routing is restored.
Hope this helps!
Michael Damon
Virtual Productions
Old 11-09-2015, 04:26 PM
latest AAX is 5.5.1.451 .. when i get a chance i will send you a session ...
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 11-10-2015, 06:36 PM
I can reproduce now, but only if I undo the commit during playback. Is this what you're experiencing? If I perform the undo action while the transport is stopped Kontakt plays fine. Only when I commit a track with Kontakt, start playback and undo while the transport is rolling does the midi connection fail. It's still a bug so it will be logged internally and we will investigate if it is something on our end or if we need to work with NI. Of the instruments I have checked so far this is only occurring with Kontakt but we will start on our end to see if we can fix.
Old 11-10-2015, 06:39 PM
interesting .. mine happens when stopped .. never even thought to try undo while it was running ..
thank you for being on this .. will post back with anymore info i find ..
cheers john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
SSD and 12.3 commit harryk Pro Tools 12 11 11-08-2015 09:49 AM
Weird issue with Kontakt 5 & controller keyboard JohnTrue Virtual Instruments 4 11-03-2013 06:45 PM
To Commit or not to Commit, that is the question. georgejw22 Pro Tools 10 10 12-20-2011 05:30 AM
How to commit? Louisblanc Pro Tools TDM Systems (Mac) 5 04-23-2009 04:26 PM
Structure Free and Kontakt 1.1 Patches - Polyphony Issue toastyt Virtual Instruments 2 11-02-2007 09:22 AM
