H/W Buffer Error 64 Bit AMD!!! update !!!!
built almost an identical system to Madrock's you however when i play back from sessions i get the Increase H/W Buffer size.... even with no plug ins no plug ins ... and playback shows my cpu meter jumping around... i played another session and it ran fine then gave me a cant get data from firewire fast enough.... I had SP 2 then did a total reformat and started without any update same issue... This all use to run fine on my P4 3 ghz.... anyone else having these issues.... if so what will digi do to fix it, im sure ill have to get a 002. When will they support 64 bit amd
Configuration. Asus A8ve-Deluxe AMD FX-55 Crucial Ballistix 1 Ghz DDR400 Seagate Barrucuda 7200 RPM SATA Drives PCIex Geforce 6800 GPU Digi 001 PLEASE HELP Anyone.. Thanks Allen.. went to the link you gave me and found updated drivers to my VIA southbridge chipset.... seems to have fixed the problem i now can play back and record audio fine.... i have once or twice gotten cant get data from drive fast enough but at least i works 95 percent of the time... i will run a DaveC test if someone can give me a link to how... Last edited by Agentemo1; 03-03-2016 at 08:49 AM. |
Re: H/W Buffer Error 64 Bit AMD!!!
Agentemo1...
I have a k8vse delux and amd 64 3400 and all is working perfect. So...amd 64's work fine. If your using winxp sp2 search how to turn off DEP in SP2. Could be alot of reasons but that is a good one to start with. |
PCI graphics is a bit of a no no - especially with the 001 - try AGP graphics that might fix the problem
cheers, Scott
"...I asked you not to tell me that!" |
I have a Kv8se delux amd 34 3400+ and I had the same problem...Even after I reinstalled Windows (I originally installed windows with SP 2) with SP 1 I was having those problems. My question to you is how big is your recording drive? I was recording to my media drive (wich I had partioned at 150 GB from a 250 GB HD)and was having the same problem....Once I started recording to my 80 GB external HD I quit having the error that said PT couldn't get data fast enough from the drive....However the access violation comes up randomly, and all you have to do to make it stop is delete your digi data base folder on your recording drive. Pro Tools runs like a well trained beast now......
I'm having a similar problem,
AMD FX 55 Asus A8ve-Deluxe 2 Seagate SATA Barracuda 7200 RPM Drives 1 Ghz Crucial Ballisix DDR 400 PCI Express 6800gt Nvidia I have received the H/W buffer error whenever i try to run off my internal Audio Drive. However i have found some new twists. When i run a session of the system drive i run into no problems. I can also run off external firewire drives no problem. Whenever i run off the other SATA internal drive it give me that error alot. I am using DMA 4 and 5 on the drives respectvly. I have used both 6.4 and 6.7 with all updates and not updates. its not pro tools related i dont think, however when i ran these drives on a pentium i had no problems. Maybe a chipset thing.. im stumped... anyone please helpe DIGI are you guys having anything like this.. Currently running on a mbox on 6.7 |
Can anyone chime in and let me know if they have had similar problems.... i dont know if there is a fix.... ?
I'm running a different board to you, however, I received similar errors at first. After turning off several windows services the problem went away. I did this so long ago I can't be more specific because I can't remeber which one was the culprit.
Sorry I can't be more specific about it...Its just al my PTLE errors always have seemed to be the fault of a bloated OS.
DIGI002 MSI K8N nForce3 25Ogb Athlon 3200+ (1Mb L2) 1 Gig PC2700 Corsair Memory 120 gig Ext USB 2.0 32+14 DaveC PT 6.9 |
I have tried disabling everything... didnt work... digi please help
List your problem in the compatiblity issues sticky at the top of the forum. I think you have a problem with that internal SATA drive. You may need to download new drivers for it. If that doesn't work try a SATA to IDE converter and hook it to one of the regular ATA ports. I would also reformat this audio drive. Or just get a new WD 80GB 8mb cache ATA drive for under 50.00 now. Good luck either way, Allen |
See the link on the Best Desktop for PTLE thread, first post under the Allenstein system. Go to the link on setting up this motherboard and click on your motherboard. There is a ton of info on setting up this motherboard correctly including the SATA ports.
Allen |
H/W Buffer Error (pro tools error -6104) Only 1 audio track running. | kieran.mia | macOS | 1 | 01-29-2013 01:39 AM |
8.04 update, Win 7, Buffer Overflow Problem | Dockside | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 08-14-2010 05:35 PM |
Increase Buffer Size Error (Buffer at MAX) ??? | PoPimp3069 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 03-29-2010 02:24 PM |
Buffer error 9129 & 9093 when turn down buffer | StackLife06 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-01-2006 09:34 PM |
Increasing Buffer Size error and update to 7.1 | session48 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-28-2006 02:05 PM |
