Setting up album format
What is the best way to comine my selected sessions into one master session for mixing and album preparation, (without killing my CPU?)
Re: Setting up album format
Record each mix to a new track in each session then export the file.
Import each to a new track in a new session called 'master'. Set up the track list in the edit window, apply your mastering plugins on each track, then bounce each down as a separate file, applying dither last to each one. Burn these files to CD using a separate program like CD Architect. Voila! Sonny |
Pro Tools does not have a mastering plug-in?
Well, at a push you could use the 7-band EQIII, DynamicsIII and Maxim if you've got that one.
Alternatively there's the lite version of Izotope's Ozone3 which is pretty cool for a quick master and came with the Ignition Pack 2. For third party plugs, I can recommend the full version of Ozone, IK Multimedia's TRacks or the Wavearts Powersuite. Even better, get dedicated plugs to do each part, like a multiband compressor (McDSP, Waves), Parametric EQ (Sonnox), Limiter (Sonnox, Massey) or other loudness maximiser (Sonnox Inflator) and maybe even a little analogue saturation (McDSP AC, Massey Tape-Head, Digidesign Reel Tap Saturation). PSP VintageWarmer 2 is also extremely cool. This will garner the best results in the box for getting the hot levels. Sonny |
I definitely will thanks, guys!
Format cannot be changed - setting up inputs | trock | Pro Tools 9 | 0 | 11-05-2010 05:14 PM |
Wave Format Extensible file format? | Joe Mendelson | Post - Surround - Video | 8 | 01-07-2008 05:18 PM |
Toast 'DVD Music Album' format | Paul Maunder | Pro Tools TDM Systems (Mac) | 0 | 03-10-2005 02:45 AM |
Looking for someone to mix an album in DC | spong | Pro Tools TDM Systems (Mac) | 3 | 04-26-2002 08:03 AM |
About to mix my first ALBUM... | Mr Peete | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-19-2002 04:23 AM |
