Old 04-22-2003, 11:22 AM
andre3000 andre3000 is offline
Default PCU Power/Processing Limits...
It seems that 5 or 6 RTAS Plugins are all I am able to get out of my well-equipped G4 system. Does anyone have any tips or tricks for getting more out of their system? I’ve been using auxiliary tracks to limit the number of plugins, but I’m still extremely limited… What can I add to my system that will provide more processing power???
ANY information is greatly appreciated.
Thanks!
Old 04-22-2003, 11:46 AM
archtop archtop is offline
Default Re: PCU Power/Processing Limits...
4 or 5?
on a well equiped g4?
I get 30 all the time.
check all the usual stuff (energy never, buffer blah, blah blah, check manual etc,
you didn't say specifically much more than your machine is a " well equiped g4 "
but thats good enough for me to say "you should be gettin' way more. Gather more data,
Old 04-22-2003, 11:48 AM
Michael Cottrell Michael Cottrell is offline
You need to share more about your system and specs ie, which model G4, OS, RAM, which version of Pro Tools, hard drives and which plugs are you trying to use. Plus any other specs you wish to share.
Old 04-22-2003, 02:02 PM
Wow… I appreciate the quick responses.
I use the Digi001 with my Power Mac G4, dual 867 Processors, with 1.5 Gigs of memory on Mac OS 9. I also record onto a companion/firewire hard drive, not directly to the computer’s hard drive.
As for plugins, I mostly utilize Realverb, Auto-Tune, Maxxbass and a few others… I think I should be able to use more plugins without encountering problems CPU power problems. When applying the plugins in mixdown, I set the buffer level to 1024 and the usage limit to either 80% or 85%. I have even allocated more of my computer’s memory to both Pro Tools and the DAE.
Thanks again for the help…
Matt
Processing Power tsungchot Windows 5 03-31-2013 02:59 PM
How much Processing Power for PT 9? maxspl Windows 12 02-24-2011 08:32 AM
CPU Processing Power Newkid1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-20-2008 01:00 PM
Processing Power shultzee13 Virtual Instruments 0 12-20-2007 06:52 AM
HD vs MIX Processing Power tomhartman Pro Tools TDM Systems (Mac) 3 01-19-2002 12:45 AM
