Mbox 2 Pro with compressor (RNC) ?
Hi...
I've got bit of a problem, I think. I'm not sure how to connect my compressor (RNC) to my Mbox 2 Pro. As it is now I have it like this: http://www.gratisupload.dk/download/35601/ But then, when I put something on my track, guitar, bass, drums etc., my comp. lights up and it seems like there is something going into it, but the signal I get in my monitors is unchanged, even if I turn the knobs like crazy. Even when I just play music in fx. Winamp I get the comp. to react, but as in Pro Tools, nothing is changed - which is good in this situation, because I don't want a compressed music file every time I play something :) So what am I doing wrong ? Is it the connection, or something in Pro Tools I need to change ? Thanks in advance. - Ylle |
Re: Mbox 2 Pro with compressor (RNC) ?
looks like you are sending the signal back from the RNC to either 3 or 4 but you have the in on the return channel set to 2. We have an Mbox pro and wrote on the back which inputs are which because the labeling is screwey and seems backasswards
It's only when it on Analog 1-2, Analog 1 or Analog 2 the comp. reacts.
If I put it on 3-4 or something, nothing happens, so... |
dude the output needs to go in the mic/line input on the mbox
What ultimately are you trying to accomplish with this?
Hmmm, almost sure I tried that, but I'll check when I get home again...
What you mean ?
What I'm trying to do with a compressor ? |
The Mbox line is really not condusive to using inserts(really, LE in general is not good at hardware inserts). If you REALLY need to record WITH a compressor, I would get a decent external mic pre, patch it thru the RNC and then into a line input on the Mbox. Remember to go easy as you can always add more compression with plugins, but you can never get rid of too much if its recorded that way.
But an external pre is hardware, so wouldn't that just go against what you said about Mbox being sucky at external hardware ? :) |
I said hardware INSERTS. Using external mic preamps is and has always been a piece of cake(and patching thru a compressor is just as simple with 1 added cable).
PT, Mbox and ext compressor | buckaroo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-16-2008 06:38 AM |
Anyone Use FMR RNC compressor with Mbox? | andrewkstone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-26-2006 08:40 AM |
FMR Really Nice Compressor & MBox? | siggy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-07-2006 08:35 AM |
dbx compressor help to use mbox inserst | Kawi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-04-2005 10:38 PM |
mbox / compressor | Kevin Canty | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-24-2002 10:36 AM |
