Pro Tools 2023 Apple Silicon Native - Video Engine/Vi Performance
Hello,
so now the AS Native version is out, what are your experiences with Avid Video Engine and Virtual Instruments? Did they change anything benefitting composers under the hood? Or it is the same code just recompiled for the AS? I am asking especially composers and post production mixers about: 1) Video Engine reliability (prone to errors) and performance 2) VI Instruments low latency performance and CPU hit, especially when using a larger, disabled template Any reports welcome.....
__________________________________ cMP 2 x 3,46, 128GB Ram Monterey 12.7.4 Metric Halo 3d 2882 I/O Lucid 88192 with Blue Sky 5.1 monitoring 10gbE ethernet with True Nas storage |
Re: Pro Tools 2023 Apple Silicon Native - Video Engine/Vi Performance
System Requirements macOS: - macOS Catalina 10.15.7 - Ventura 13.2.0 - M2, M1 or Intel Dual Core i5 or faster For more information on supported computer models, please click here. https://avid.secure.force.com/pkb/ar...rating-Systems
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
It seems more stable than under rosseta for sure, but I still can’t bounce a movie more than one time without restarting, otherwise Protools would lock and spin…
I haven't used PT Native w/ video enough to judge but I'll keep an eye on it now that I'm in Native more often. There have been MANY "video engine stopped unexpectedly" in the past so I also hope that they've ironed this out.
I've not had any VI issues w/ PT 2022.12 that were attributable to PT itself, but I've had plenty of issues with individual VIs where I'd have to put the blame on the plugin developers. In other words, PT is a decent enough platform for VIs. But could it improve? Probably. Kicking Rosetta out of bed can't hurt. |
As somebody who has used VIs
I tried for the better part of two decades to get Protools to just work where I can go forward without always juggling resources… Five years ago I just needed a second DAW so I could create without this knife edge… Using an old license from ableton live I updated it and realized I could just go forward pretty quickly doing whatever I needed to and if I had a limit I would get a little crackling… As opposed to One day Protools I could run a couple of things next day even one contact instance would go Into a tailspin This was the same version of kontact on either DAW one could run many reliably, one PT was so erratic that I could not rely on it… So let’s get back to the subject at hand but I just wanted to point out the same plug-ins that work fine… And I mean fine- in other DAW’s all of a sudden a problem for ProTools Even after us waiting through years of their transition out of TDM to a X etc. it seems to be some sort of garbage pit of zeros and ones that quagmire they create
Hal Cragin On the DUC Since The Year 2000 AD Ventura ,PT 2022.10, MacbookPro 13"[2020] M1 16G, Antelope Orion 32+ Gen3..SSL Sigma summing, SMART Comp C1LA, CharterOak EQP-1 Oceanway Audio HR4S monitors . SSL X-Rack w XR618 compressors, dbx 160x [2] |
I'll report when I can, but I have been running Rosetta 2 for months and never really tried to use the Beta Native, simply because in my world I could not afford to not have access to plugins I used constantly. I will run some tests here and get back to folks on this, but with all that has changed in the last year in my room, I am just happy to have a new Mac Studio operational and am on Monterey by choice for work. Saw no need to update to Ventura at all even though it's approved. I felt it was not ready for prime time for my use.
Excited about the Native ProTools, but am guessing for me I am not sure it's really necessary at this point, but welcome it when it is even more solid. I just upgraded to the new version last night at 9pm and have not run a session other than to get things all setup. Had to install the Hardware Driver twice for some reason, but it's fine now. THE MOVIE Bounce is I feel an Apple related issue, but hope they get it sorted out. It seems to come and go with crashes, but not really had any lately in the prior 2022.12 or even earlier. One day it happened all the time after a couple of movie bounces, but then either logged out or restarted made it perform normally. It always seems to happen when I need it quick. Hah. G
The only issue I have is with Arcade which has can get caught in a loop when too many instances of Arcade are present. Hit stop and the samples keep playing. This has been a problem for years and Output can't seem to fix it. Coworkers who use Logic say that they don't get the same issue. But this is simply a matter of the plugin not receiving "off" messages.
On a well-configured system there shouldn't be any PT-specific VI issues that I'm aware of. Kontakt's issues aren't exclusive to PT, and V7 seems to have fixed many things. It's certainly working well here. |
I don't run video in Pro Tools (unless I'm doing an audio-only layback mix against VO/SFX), and that has been a big help. I keep the video in NLA's Video Sync. As a reminder, always make your vids ProRes or DNxHD, and don't load MP4s in your DAW or Video Sync. That will help a lot.
I haven't had many problems with Vis in PT since I offloaded the video 7 years ago. I run a lot of VIs of different sorts, and learned to manage it pretty well on my old Mac Pro 5,1. It would protest at times if I was mixing and had a load of active VI tracks, with a lot of ML-powered plugins (Soothe2, Gullfoss, Ozone, etc). Since I replaced it with a Mac Studio 4 months ago, I've had ZERO VI problems. I mean running sessions with 2 drum VIs, a suite of orchestral percussion, full sections of orchestra, vocals, a few synth parts... It's been great. My template is made up of a ton of disabled tracks (and disabled plugins on audio/aux tracks). I've fiddled a bit with the AS native version, but since I'd have to convert all of my Kontakt instances to Kontakt 7 instances MANUALLY, I haven't fully dived in. But it does seem like the VIs that have been adapted to Silicon in my template all seem to work really smoothly. FWIW, I do work in stereo at 48k, so I can't speak ti pushing it to 5.1 at 96k, etc...
Kerry Smith http://apothekerry.com Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro Last edited by massivekerry; 03-25-2023 at 03:17 PM. Reason: clarity |
Just checked and the video engine is still running in Rosetta, even running Pro Tools in native mode. I’m fairly certain not much has changed there since the last version but I hope I’m wrong on that front!
Sent from my iPhone using Tapatalk |
2023 Apple Silicon and Pro Tools | Chevron | Pro Tools | 59 | 03-21-2023 07:54 AM |
32 Channel - Apple Silicon - Pro Tools Rig in 2023 ? | T-Low | Pro Tools HDX & HD Native Systems (Mac) | 25 | 01-02-2023 09:30 PM |
Pro Tools and Native Apple Silicon use... | lowthert | macOS | 10 | 07-24-2022 08:01 AM |
Playback Engine Crashing On Apple Silicon | Rico618 | Pro Tools | 0 | 02-23-2022 07:43 AM |
