Sound Replacer doesn't replace....
Hello,
I am a long time PT user and I upgraded my trusty G4 and 001 to a 8 core Mac Pro and 003 rack. Included in my purchase was the Sound Replace plug which I used to like quite a bit. I have the authorization on my ilok and it loads just fine but does not process any audio and will not even preview. I have downloaded the plug several times thinking it was maybe corrupted or something, but everything seems fine, it just doesn't work...... Any suggestions greatly appreciated. Thanks |
Re: Sound Replacer doesn't replace....
Have you used the plug in updater. SR is on the list that gets updated for 8 (Or maybe even for 8.0.3. I was using it tonight and it works fine in 8.0.4.
Link Here. |
I don't think that's it, but thanks for the thought. I just upgraded to 8.0.4 and it has a plugin updater included, and I checked the version and its soundreplacer version 8.0 which apparently is the right one. I can't get it to work either on my tower with 003 or laptop (macbook pro w/ mbox2). Weird.
I finally got it to work but you have to basically keep trying it. If it doesn't render the waveform, you need to undo Command-Z then do it again. It finally works after a few tries. It does suck that it isn't that great of a plug-in anymore. I need to find a better drum replacer plug-in.
Mac Pro Dual Quad 2.8Ghz 2008 MacBook Pro i7 2012 OSX 10.8.5 - OSX 10.7.5 Pro Tools 10.3.7 - 11.1.2 6GB RAM Universal Audio Apollo Quad!!! Eleven Rack Focusrite Octopre MKII Yamaha HS80s Rockit RP5 Monitors w/ RP10 sub |
It loads and looks fine but will not preview or render files. Very frustrating... |
Is 'use in playlist' engaged?
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
yup. engaged. wont even preview. but loads waveform into the window and calculates threshold etc. just doesn't do any of the replacing....
Figured it out....
I was loading SDII files as samples and their no longer supported. AIFF and waves seems to work fine. Thanks for the replies. Cheers |
Sound Replacer HELP!!! | Audio85 | Pro Tools SE and Essential (Mac) | 4 | 06-08-2010 11:23 PM |
does syncronic replace sound replacer? | tomcat | Pro Tools TDM Systems (Mac) | 6 | 07-06-2006 04:59 PM |
Is there a drum replacer/sound replacer??? | sethbrand | General Discussion | 2 | 03-08-2006 08:40 AM |
my sound replacer makes the samples sound higher | joeldavidlauver | Pro Tools TDM Systems (Mac) | 2 | 05-24-2005 07:59 AM |
Sound Replacer Alters Sound of Sample. | vze24x2x | Pro Tools TDM Systems (Mac) | 0 | 10-25-2003 07:10 PM |
