PT 10.3 start up problem
hi there
i suppose that to see better then a lot of words, so ppl, tell me plz - has anybody that problem http://i48.tinypic.com/dfhwj.jpg as soon as it appears PT stops responding and no adjustments can be done or menu opened. what do you think, is there some solution or just quit PT and forget it for ever becouse of its instability? Win 8 core x64 core 2 duo, 4gb ram etc... |
Re: PT 10.3 start up problem
well-well
I've read a lot of your posts and i'm unable to understand all this at all - why on earth, you ppl make f**g troubles to yourself dealin' this full of errors, glitches etc program with ? pro tools is total crap and even not x64 I respect all of you, but can not get you.. good luck. |
Couldnt open your pic at work as due to internet restrictions, from what you have put as your spec you are using windows 8 and avid do not support Pro Tools on windows 8 so thats probaly your issue
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
But wait, there's more! Your system has 4GB of RAM? That's barely enough to run Windows, plus Pro Tools, so there is nothing left over(for RAM) to caching. Is Disk Playback Cache Size should be set to the lowest number(256meg) and have you trashed prefs? Trashing Pro Tools does no good as most of us make a living with it(or at least a lot of music)
When you click on Pro Tools hold down the "N" key until your playback engine window pops up... turn OFF disk caching, lower your DAE buffer and click OK.... It should load from there.
Pro Tools is the industry standard for professional DAW's... Its not the software, its you. |
Problem on start up | Gaz103 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-29-2006 11:18 AM |
start up problem | Han_PT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-01-2005 03:43 PM |
Problem with start up | onezero | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-27-2001 07:23 AM |
DAE start problem (& others) | wilseven | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-29-2000 07:59 AM |
start up problem | Hendrik | Pro Tools TDM Systems (Mac) | 0 | 04-20-2000 01:45 PM |
