New Massey DRT is out
New Massey drum replacement plug is out. Video on the site. As usual great value at $69. Same principle as the original it seems but with new detection algos etc.
http://www.masseyplugins.com/
Denis Mac Pro 3.3 hexacore 24 gb RAM Lion PT 10 HD Native |
Re: New Massey DRT is out
The histograms on the loudness and sensitivity sliders are absolutely brilliant.
brilliant.
@wildhoneymusic http://kidzbop.com/music/ https://concord.com/publishing-roster/gary-philips/ |
Just bought it. Looks great. The print clicks thing is also a brilliant idea, at least for guys like me, that don't want to use midi.
Love the histogram based filtering. DTM has been great and this looks to be the new king.
Larry Cellar Dweller Productions PT 2020.3.0 HDX, HD IO 16x16 analog, 192 I/O, Control|24 Mac Pro 2019 16-core, 96GB RAM, OS 10.15.2 |
...and you can add & subtract transient markers really easily.
First off, I'm a huge Steven Massey fan. I do, however, have a little complaint about this new, mostly awesome, plugin. I've found that, despite it's amazing detection algorithm, it does not track the dynamic range of the source track very well. The ghost note detection points are too close in dynamic level to the louder hits. I do know, of course, that you can go in and manually adjust the triggers but man is that time consuming if you have a lot of these notes going on in a performance. It'd also be great if you could group a bunch of triggers together and move them all at once. I've tried every other parameter that I can see that's available and have not been able to get a big enough dynamic range in the trigger points. Maybe it's just that I'm missing something. Any suggestion would be great.
Thanks Scott, but I don't use midi to trigger samples. I use the "print clicks" feature to create a clean trigger track for Trigger, of all things. I don't trust midi triggering to be sample accurate with the original audio. But, even if I did use midi, it makes no sense to me that DRT shouldn't be capable of accurately detecting the proper and compleat dynamic range of the source audio. There really shouldn't be any need to adjust the dynamics in midi after a midi track has been generated by DRT. In lew of the detection algorithm being improved it would be a time saver if it were possible to lasso groups of selected triggers within DRT and drag down those velocities all at once.
Thanks for bringing this up. You were right. There was some unintended compression going on. I've updated the plugin and a new installer is available for download. Hope this helps out. |
WTB: Massey VT3 EQ | dawsonaudio | Buy & Sell | 0 | 11-22-2012 09:46 AM |
Massey DTM PT9 | Siegfried Meier | Pro Tools 9 | 2 | 11-15-2010 12:18 PM |
Massey DTM and 8.0.3 | @ndy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 04-01-2010 06:28 PM |
Massey DTM... came and went? | theaero | Pro Tools TDM Systems (Mac) | 23 | 09-25-2009 11:59 AM |
Massey CT4 | hearttimes | Pro Tools TDM Systems (Mac) | 23 | 11-16-2006 05:08 PM |
