SYNC HD clock source
Greetings,
We have a SYNC HD on our system because we do a fair amount of ADR work and need to be able to generate or lock to TC when working with remote facilities. Back in the day we were working with 3/4" and Beta decks, so we were using LYNX modules, with everything (including the SYNC HD) referenced to blackburst. But now we're working exclusively with QT movies; all the external video gear is gone. My question is this: since we are no longer referencing the SYNC HD to blackburst, I'm wondering if there's really much difference between having the SYNC HD be the loop master and having, say, one of our (blue) 192 i/o's as loop master. Is there any significant improvement in the SYNC HD clock over the interface? I mean, if there is I can't really hear it, but maybe there are other issues I'm not considering? Thanks for any thoughts. |
Re: SYNC HD clock source
Without a genlocked video output for QuickTime video, such as you'd get from MOJO or Blackmagic Decklink, and no external gear to lock to, and no need to varispeed, SyncHD serves no purpose. Video and audio will generally stay in sync within a frame (if you've got a recent cpu and the QuickTime movie codec/resolution is not overly demanding). Pro Tools will drag the video along with audio so there is not worry of long term drift. It certainly wouldn't hurt the AD converters jitter performance.
Operating that way makes lipsync a little too sloppy for my tastes but many people do it. It is very cost effective. |
MacPro 7.1 8c 3.5 GHz, 48GB RAM, HD native PT 2021.12.0, 10.15.7 www.imdb.com/name/nm0501611/ |
Thanks. One further question: frame edge alignment to an external video reference only or to Quicktime Videos in floating windows as well?
QT floating windows are unpredictable on the sub-frame level. The "mechanics" of typical graphic card outputs, combined with the flexible treatment of video by QuickTime, defeats any attempts to align Pro Tools audio to video with subframe accuracy. Pro Tools cannot know exactly where frames edges are. Therefore when using a floating QT window, audio will be out of sync by a random amount of subframes. |
Thanks for the thoughts. Our work isn't critical enough that I'm worried about subframe accuracy. The SYNC HD does continue to serve a purpose, however, in that we typically act as "master" during ADR sessions, so the SYNC HD generates LTC that we send by ISDN to the remote ("slave") facility.
My question was more about clocking though, not about video sync. I just want to know if the clock in the SYNC HD is in some way superior to that in the 192 i/o. |
It´s rather academical for but if you want to know exactly read this:
http://akmedia.digidesign.com/suppor...tter_30957.pdf or take a short-cut to the conclusion on the last page.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
the link is dead; could you please point to this pdf again? thnx!!
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD |
here again http://akmedia.digidesign.com/suppor...tter_30957.pdf If that doesn't work paste the link into google. it should find it.
Problem detected with audio clock. Check that your clock source and sample rate are c | Solow1nonly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-06-2011 08:22 PM |
Got some trouble with clock "mismatch of sync source" | soundonthemoon | Pro Tools TDM Systems (Mac) | 0 | 09-21-2010 11:07 AM |
"Problem detected with audio clock. Check that your clock source and sample......... | ASD15 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 03-26-2010 03:40 PM |
Problem SYNC I/0 Clock Source PT 6.9 | y2kmessiah | Pro Tools TDM Systems (Mac) | 2 | 04-25-2005 08:58 AM |
Aard Sync or Lucid for a clock source | M.Landolt | General Discussion | 1 | 02-13-2002 10:07 PM |
