new system experiencing problems with latency
I believe that i'm having an issue with my firewire ports. The pc i'm using is brand new. i had it custom built. protools runs fine, but whenever i try to record through my firewire 1814, there's a wicked delay. i tried adjusting the playback buffer to no avail. i'm pretty clueless as to what to do.
Re: new system experiencing problems with latency
i forgot to include my specs
custom built w/Intel core 2 cpu 6400 @ 2.13GHz, 2GB of ram XP pro version 2002 service pack 2 ProTools M-Powered v. 7.1 M-Audio firewire 1814 2 300G WesternDigital SATA-II hard drives |
Did you mean the Hardware buffer? Your post says Playback buffer, which is not going to solve your recording problem. For recording you want to adjust the Hardware Buffer to as low as your system will handle. I usually use 128 samples for cutting drums and 256 samples for cutting everything else.
Any one experiencing similar problems? | pcombs | Pro Tools TDM Systems (Mac) | 3 | 02-10-2008 11:22 PM |
Anyone experiencing problems with 5.3.1 saved as 5.x? | ragbor | Pro Tools TDM Systems (Mac) | 5 | 10-12-2002 10:10 AM |
Experiencing latency recording audio and MIDI in a really good system... why? | Alexis CC | Digidesign Hardware & Software | 2 | 09-14-2002 12:07 AM |
Experiencing numerous problems, any help greatly appreciated | Dj Winter | Digidesign Hardware & Software | 2 | 05-04-2002 02:51 AM |
Experiencing numerous problems, any help greatly appreciated | Dj Winter | Digidesign Hardware & Software | 0 | 05-02-2002 08:38 PM |
