volume/peak/delay indicator problem
hello
i'm using a protools 6.2.2. with mbox on an ibook g4 10.3.2. my problem is that in protools the delay indicator always shows "zero". when i am inserting a delay plugin it also shows zero. i dont have installed any tdm plugins. ok i had some time ago then somebody told me to delete them so the indicator works right. it worked for some days but now it doesnt. i dont know what it is, also uninstalling ALL plugins and just installing the EQII from the digirack plugins wouldnt work. i hope somebody can help me. zad |
Re: volume/peak/delay indicator problem
If you mean the latency delay, it will not show the delay setting of a delay plugin, ony any latency delay due to plugin use on the track.
i know this! but a delay plugin is BUILT!!!!!! to produce latency in order to delay an audio signal or not? so the indicator would display the time that a signal needs to run through the delay plugin + the delay itself in samples.
that's not how it works. the latency delay only reads the latency fo the plugin, not the delay setting as well. that is a function of the plugin, not an affect of it's use and latency. The plugin will give you a delay readout in it's interface.
ok you're right. thanks that we discussed this. but that didnt help me much with my problem. the display shows zero thats the point!
HTH
Steve Always err on the side of perfection. |
i cant believe it seems like you are right. the plugins FROM digidesign IN a digidesign software dont support this function??? thats ... how can i use this function anyway? playing one track, routing it to another audiotrack and record it again? or any other suggestions?
peak indicator and indexing in PT9? | Lou Judson | macOS | 4 | 05-12-2011 12:11 PM |
volume/peak/delay, delay shown in samples or ms? | Ziko | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-29-2008 04:11 PM |
volume/peak/delay meter | Cammo2009 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-14-2004 11:16 PM |
Peak indicator | d_matt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-14-2003 03:38 PM |
volume/peak/delay display | Fave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-21-2002 09:22 PM |
