Compatibility..Final Word
Hi Guys,
Pretty Please..... Would everyone who reads this just quickly post your hardware configuration success stories here? I'd really like to see, in one spot, a low down of all completely successful setups(including drive types, chipset type etc.). Please only post if you are satisfied with your DIGI001/Win98SE performance. I've seen some successful setups which do not conform to the prescribed standard, and would like to try to find some commonalities between them. This could be interesting to all, including DigiDesign. I still plan on building a digi spec pc, but who knows. Thanks to all in advance, Darrin |
Re: Compatibility..Final Word
Here goes nothing:
Hewlett Packard Pavilion 8613 600Mhz PIII (don't know the m/board) 256MB P100 SDRAM (2x 128) Win98 and WinME on seperate partitions Quantum Fireball 10Gb system drive (IDE bus1) HP CD-RW (IDE bus2) Digi001 in PCI#1 Promise ATA100 adapter card in PCI#2 IBM Deskstar audio drives (30GB & 46GB) 7200 rpm / 8.5ms / run from the ATA100 card Tekram UW-315 SCSI controller in PCI#3 (for zip/jaz/external backup drive) Aureal Vortex (cheap & nasty) soundcard in PCI#4 for CD audio playback and system sounds (normally disabled though) Uprated power supply (forget which one) Performance with Logic Platinum is 24 to 32 tracks at 48Khz / 24bit and the same number of plugins. (I tend to use the busses heavily; with global effects like compressors/reverbs/delays/phaser etc on the bus; and still have room for filter/EQ/sfx on each track)
// Disuye Records HK // Loopmusic Productions |
Asus P3B-F - BIOS Rev 1006 - 440BX chipset
Intel PIII 650 Slot 1 - 100MHz FSB 256Mb PC-100 SDRAM ATI All-in-Wonder 128 AGP 16Mb (Driver ver. 4.11.6263) I/O Magic (Promise chipset) ATA 66 PCI controller (in PCI slot #1) Sound Blaster Live! Value (in PCI slot #2) Creative PCI Flash 56 Voice Modem (in PCI slot #3) Digi 001 (in PCI slot #5) Maxtor 9 2041U4 ATA 66 20Gb 5400 RPM system drive (alone on CH-1 of ATA66 controller) Maxtor 5 2049U4 ATA 66 20Gb 7200 RPM audio drive (alone on CH-2 of ATA66 controller) HP 9100i CD-RW (alone on CH-1 of motherboard ATA33 controller) Toshiba SD-M1212 DVD ROM (master on CH-2 of motherboard ATA33 controller) Iomega Zip 250 (slave on CH-2 of motherboard ATA33 controller) Sony 3.5" floppy drive Many fans blowing in all the right places 350 Watt double fan power supply (I've also run the same configuration but with a PIII 500MHz with good success)
-- Mike - HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics - Windows 11 - PT 2021.12 - PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i - Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs |
Well now, let's see.
ABIT BE6-II, Rev. 1.2 w/'UJ' (9/5/2000) BIOS update P3-800E (100FSB) 256MB SDRAM, PC100 Promise ATA 100, IDE controller (Data drive only) System drive: Western Digital-Caviar, 13GB, running on onboard controller Master-IDE, ch. 1 Data drive: Seagate-Barracuda II, 30.8GB, running on Promise controller CD-R/CD-ROM: Yamaha-CD8824, running on onboard controller Master-IDE, ch. 2 3.5" Teac floppy (which will be leaving soon) AGP/PCI Buss: Video: Diamond Fire GL1000 Pro, AGP, running the latest and the LAST set of drivers from Diamond/3D-Labs Networking: 3COM-XL10/100, installed in PCI slot #2 Digi001: Installed in PCI slot#4 Controller: Promise ATA100 installed in PCI slot #5 Rack mount case with 350 watt (Nuclear controls) power supply Fresh install of 98SE w/service pack 1 & Direct X 8.0. All required Win. config. changes as required by Digi install guide book. Cakewalk 9 Pro, Office 97, Corel Draw 8, Adaptec CD-R software loaded only. Then installed Digi LAST. I also loaded DVERB. I run this computer on my network. But I don't recommend doing this during any recording. Especially tracking. Due to the possiblity of 'someone' trying to gain access to any shared files with Digig is recording and forcing the CPU to alter the access to the PCI buss. But it makes upgrading drivers and such a breeze. So much so I have no need for my 3.5" floppy anymore. Notice I don't run a second sound card. The Digi001 system (at least mine anyhow) does everything that it advertises. I have had ZERO trouble since loading/building this machine (9/9/2000). I guess I'm lucky. [This message has been edited by Lowfreq (edited December 27, 2000).] |
Hi there !
extremely happy with the following config. (Hardly any problems since July 2000, daily big sessions) : Motherboard : ASUS P3B-F (BX440) CPU : Pentium III 667 VGA : Trident 9750 AGP 4Mb RAM : 256 Mb HD System : IDE Fujitsu 4.3 Gb 5400 rpm HD Audio : IDE Ibm 20 Gb 7200 rpm CDRW : HP 9110i 8/4/32 CD Rom : Actima 36x Sound Card : Creative Labs Awe 64 Gold (disabled) Good luck ! ------------------ Paul Curtiz / Scratch Studio |
My setup has been flawless, I'm very happy!
Pent III 600 Mhz Intel SE 440 BX-2 Motherboard ATI 8MB video card Ioflex ultra ata-66 Controller card 15.3 G Seagate ultra ata 66 7200rpm HD(system) 20.5 G " " (Audio HD) 384 MB RAM Plextor 8x4x32 Atapi burner This system was custom built and I have experienced NO PROBLEMS! I max out 24 tracks of audio with plugins on a daily basis, no sweat for this machine. |
Hi
Just purshased an HP 8754 to run the 001, (pretty similar to what you have) . It is running WinMe and so I get that "device heap" messsage when I installed 001. I am now considering doing what you have done and setup a dual boot with Win98SE. How did you setup you computer for dual boot with WinMe already installed? Very much appreciate your help! Thanks <BLOCKQUOTE><font size="1" face="Arial,Helvetica,sans-serif">quote:<HR>Originally posted by loopmusic: Here goes nothing: Hewlett Packard Pavilion 8613 600Mhz PIII (don't know the m/board) 256MB P100 SDRAM (2x 128) Win98 and WinME on seperate partitions Quantum Fireball 10Gb system drive (IDE bus1) HP CD-RW (IDE bus2) Digi001 in PCI#1 Promise ATA100 adapter card in PCI#2 IBM Deskstar audio drives (30GB & 46GB) 7200 rpm / 8.5ms / run from the ATA100 card Tekram UW-315 SCSI controller in PCI#3 (for zip/jaz/external backup drive) Aureal Vortex (cheap & nasty) soundcard in PCI#4 for CD audio playback and system sounds (normally disabled though) Uprated power supply (forget which one) Performance with Logic Platinum is 24 to 32 tracks at 48Khz / 24bit and the same number of plugins. (I tend to use the busses heavily; with global effects like compressors/reverbs/delays/phaser etc on the bus; and still have room for filter/EQ/sfx on each track)<HR></BLOCKQUOTE> |
Hey Foreigndog,
I have a very similar system setup. You mentioned in another post that you got yours from Wave Digital. I modeled my system after the specs on their website. I am trying to tweak a couple of performance issues and was hoping you might be able to supply me with some information regarding your system: Into which PCI Slot do you have your Digi card inserted? Which PCI slot for your ata66 controller? Is the Digi sharing an IRQ with any other device? Which IRQ is it using? Thanks for your help, Bentley Ousley |
This system usually gets me 24 tracks, however it's a little underpowered. Mostof my sessions are less than 16 tracks though anyway, and I do get 16 trax+ plugins no prob.
No-name setup: -ASUS P2B, 440BX chipset, Award BIOS version 1011 (I had to upgrade this myself to work with my 45 GB hard drive, it was a nightmare) -Intel Pentium II-400 -256 MB RAM -System drive 20 18GB Maxtor 7200 RPM -Audio Drive IBM 45GB 7200 RPM, partitioned into 10 GB (samples) and 35 GB (sessions) -AGP-nVidia RIVA TNT -slot 1 empty -slot 2-DIGI 001 PCI card -slot 3 empty -Slot 4 3Com 10baseT Ethernet card -Slot 5 Creative Soundblaster 64 AWE PCI -slot6 empty |
WinME (apparently) allows dual boot; giving you the option to decided which OS you want upon startup. However; I couldn't get this to work and have gone about it the long way:
Get hold of a cheap program called 'Partition Magic' which will partition any drive either for storage or system use. When you want to change back to the "other" OS; you run partition magic / hide the current partition / make the other the partition active and reboot. Just make sure that 'Partition Magic' is installed on both sides of your PC otherwise you are buggered! If you want more specific details on how to partition your drive - mail me directly ICQ#55087283
Firewire 400 verses 800-the final word please | boneboy | Pro Tools TDM Systems (Mac) | 9 | 03-13-2009 02:54 AM |
The final word on GarageBand | silverlode | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-02-2004 01:50 PM |
Final word on 'do the levels within a plug in' (waves etc) issue | Jules | Pro Tools TDM Systems (Mac) | 9 | 09-04-2001 06:15 AM |
What is the final word on VIA, 815E, Soundblaster... | Noboby f**** with Jesus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-17-2000 01:45 AM |
The final word on WAVES plug-ins! | link | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-30-2000 11:58 PM |
