Strike - adding 1/2 bar measure without remapping patterns?
I've got a song that unwittingly sounds best if I add an extra beat (1/2 bar in measure) during the breakdown - halfway through this particular song. But this extra 1/2 bar throws all my (Strike) drum patterns awry after this point in the song.
Can I adjust for this without having to rewrite patterns to suit? I've figured I can bounce down the drums and cut/paste the measure in, but I want to avoid this if possible. |
Re: Strike - adding 1/2 bar measure without remapping patterns?
Do you want Strike to play a half bar or stop?
I work with amazing people who do incredible things. Founder of the Expert Sites. |
I don't use Strike, but if I remember correctly, for your half bar just change your meter to 2/4 for one bar then back to 4/4, (assuming 4/4). Strike will follow the "one" for your patterns I believe... Russ???
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
It depends what he's trying to do...
At the end of the extra 1/2 bar, pencil in a "Stop Playback" command for Strike (The red key, note C1). Then, pencil in a fresh command in the next bar to restart the desired pattern.
It's not that simple, you need to create a meter change to take it to 2/4 then back to 4/4 and also a pattern to account for that.
I definitely want Strike to play that half bar. But after this point it just triggers the last half of the patterns in Strike - switching the groove from 2 and 4, to 1 and 3, likewise with the fills too - they sound more out-of-whack than the patterns.
I've tried latching/unlatching with the midi map, messing with the 'stop playback', but the patterns all adhere to the bar and beat, and I can't think of how to add the 1/2 measure within Strike. I'm not sure i've ever messed with the time signature in PT, but a bar of 2/4 would provide the perfect solution. I'll give that a go. |
So then I tried penciling in a "Stop Playback" command at the end of the half measure, and a new note to re-trigger the pattern, in combination with the meter changes, and it worked. In my other post, I forgot to mention that I had also inserted one measure of 2/4. Come to think of it, instead of creating a measure of 2/4, you may be able to make a measure of 6/4 (this would account for 1 full measure plus the half measure), then back to 4/4. |
OK - changing the meter to 2/4 for the breakdown (not just the 1/2 bar) worked a treat, but now i'm having trouble following the patterns within Strike, or more succinctly, having trouble editing the patterns to sound 'just so'.
For example - I just changed a pattern to suit, but to change the start of the pattern in playback, I had to change the last 1/4 of the pattern in Strike... now i'm getting lost!!! |
However with 6/4 you would have to write a new pattern to account for the extra two beats. with a measure of 4/4, 2/4, 4/4 it would just stop the existing pattern halfway through and start again on one.
Adding Measure | Jel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-22-2012 05:43 AM |
Strike Drum Patterns | jPaul | Virtual Instruments | 2 | 02-03-2011 05:09 PM |
Strike Patterns Don't Sound | quantise | Virtual Instruments | 10 | 11-03-2008 04:50 PM |
can you tap out patterns/create patterns in strike | 4thfloorstudio | Virtual Instruments | 4 | 09-15-2006 11:14 AM |
Patterns in Strike | songman | Virtual Instruments | 0 | 09-07-2006 05:49 AM |
