PT 2021.7 - crash while loading session
Hi Avid-Fam,
I am on OS 11.6 with PT 2021.7 and having some troubles while loading a specific session. Everytime I am loading this session (around 30 tracks with maybe 50-60 plugins activated) PT crashes without any feedback while restoring the single tracks. Most of the time PT crashes while restoring track "Snare" (3 plugins loaded there). If I am loading this session without any plugin (holding SHIFT), everything is fine. Afterwards I am activating all the plugins per instance (CONTROL+OPTION+CMD) manually without any crash or error. What's the reason for this behaviour? How can I find out the suspect plugin or reason for the crash without any report? Thanks for any help. Mike PS: I trashed all prefs with PT Prefs already.
Composer/Keyboarder iMac Pro 10 Core 64 GB RAM Vega 64 Pro Tools 2023.12/Ventura 13.6.1 Beyerdynamic DT 770 Pro ______________________________ |
Re: PT 2021.7 - crash while loading session
My first guess is that you may have a plugin that is not compatible with either the OS or the version of Protools you are running. MacOS 11.6 is relative new and not all plugins are updated for it yet. Likewise Protools 2021.7 has only been out about 3 months and so some plugins are not updated for it yet. Check with the plugin manufacturers to see if they have an updated version available. Otherwise you may have to do without that plugin (or use a similar plugin) for now.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
@Obsidian Dragon:
Thank you, but how will i find the suspect plugin easy? I do not get any feedback like plugin x caused the crash. I do not want to commit all tracks and doing the session without plugins. It is strange that if I load the session without plugins and activate all instances of plugins afterwards the session does not end in any error. @JFreak: Thank you, might be a reason. Is this really necessary? I can unload all plugins while opening the session with holding SHIFT. But as I wrote above, it does not help to find the suspect plugin with little effort Mike
Yes, for troubleshooting, unfortunately it is necessary. If a rogue plugin is loaded into memory (when the list of plugins run on splash screen) then it is an issue even if not instantiated. Only way to rule out plugin problem is to move them temporarily to unused folder.
It's not that daunting to move-test-putback repeat!
Carve out a two hour session for maintenance. (Billable downtime) Computer creatives need to do this (Type of thang). (Or be at the mercy of...) Remember. We Are The Hat Generation.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
To add to Detroit
To speed up the manual process of moving them all out then adding back in,,, you can do semi-bulk add-ins ,,,, of say 5 or 10 back in at a time , (depending on how many plugins you have) which will go much faster and fairly quickly tell which sub-set has the problem plugin.. and then you test them individually
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
@JFreak: Ok. Then I will dive into this annoying work. Unfortunately, I have several hundred plugins (PA-stuff alone is more than 100+).
But, I do not get the point with this method. Moving all plugins into the unused folder leads to a Missing AAX Plugins error while loading my spec. session showing me all the single plugins which are missed for this session. So, I have to put these plugins only back to plugins-folder and restart PT and see what happens? Whats the advantage? Putting "semi-bulk addins of 5 or 10 back as @KRoche suggests does not help with this specific session to my understanding because I have to concentrate on those plugins first which are missed for this specific session. Sorry, maybe I am "off the track". Thanks Mike
Sadly, this is the only bulletproof way of troubleshooting plugins. Whenever a plugin is loaded into memory, it contributes to the stability (or instability) of the whole system even if it is not instantiated in a session.
If you have zero problems without plugins, you first rule out a PT problem. Then you keep moving plugins back one vendor at the time, and once the problems re-appear, you know which plugins are the culprit. Then you move those back to unused, and the rest to the plugins folder and if the problem keeps away you know you have found it, and likely will either try to find update to said plugins or ask the vendor for support.
You are on unsupported software combination, but yes, try to move all plugins to unused folder and see if it opens. Most likely one plugin behaving badly.
HELP!
Being a new mac user, I got excited about the new mac os Monterey 12.0.1 that was released yesterday (10/25). After installing and booting, being a Pro Tools addict I immediately double clicked the Pro Tools icon on my dashboard and attempted to load my newest tracking template I have been building (I am using Pro Tools version 2021.7). After the loading screen faded away and the program was booting up and initializing my tracks, it made it all the way through loading my tracks until it got to the Lead bus. I starred at my screen for almost 10 minutes waiting for my session file to boot to no avail. After several restarts and other templates, still no sessions would boot. At first, I thought it was the Pro Tools DAW as a whole, but then I realized you could boot files while holding shift to load the session file with all plugins inactive. This allowed me to open any session file or template file I wanted with no problem. Ozone being a pain in the butt sometimes and some of you may know, I immediately blamed it for being the problem, which it was. I opened a new Ozone 9 plugin in a random insert section on another bus and the entire session crashed. After identifying ozone as the culprit, I thought I was out of the woods and began trying to boot my original tracking template (without holding shift); and the EXACT same thing happened again. While loading my tracks in the loading screen, it would get to the "LD" bus, and completely freeze up. After doing the shift boot again on another session file, it booted up, and I began to move though the plugins I have on my LD bus specifically (a few waves plugins and stock Avid plugins). PULTEC EQP-1A WAS BREAKING MY SESSIONS!!! I have been using the Avid EQP-1A on my LD bus for months now along side the D3 deesser from Avid. After initializing both plugins on a new Aux track, the D3 came up with no problem, but as soon as I made a new EQP-1A from the plug in list, the spinning beach ball reappeared and the whole session froze up again. After taking them both off of all my buses on my templates, everything has been working fine and I am starting to like OS Monterey. But somehow, Ozone and the Pultec EQP-1A are still causing problems. IS ANYONE ELSE NOTICING THIS???? I would love some feedback, thank you!!! |
Pro Tools 2021.6 crash / freeze after offline bounce | innerbooty | Pro Tools | 5 | 09-13-2021 12:16 PM |
Video File Loading in PT 2021.6 | epm | Post - Surround - Video | 6 | 06-25-2021 07:32 AM |
Protools 9 crash entire PC while loading a session | libeats | Windows | 29 | 06-10-2013 06:53 AM |
loading session crash | mike666 | Windows | 6 | 06-26-2012 04:43 PM |
Grey-screen Full crash on loading session - ideas ?? | Ru_C | Pro Tools TDM Systems (Mac) | 4 | 07-29-2011 05:40 AM |
